to any1 with a blox intake manifold....
i am having some serious low idle problems… i have checked almost everthing i can think of… i recently installed my new blox manifold and i think that maybe the problem… cause the car ran fine with the stock 1… before i remove it and put my stock one back on… i just wanted to see howmany of you guys are running a blox mani and if it works fine for you…
3-bar map sensor has been tested
vaccum lines are correct and not leaking
TB gasket- no leaks
no FITV/ I have a blox manifold.
cleaned IACV and made shure it has been properly pluged in…
TPS is plugged in…
NO- check engine light.
when i unplug the brake booster line from the IM the car idles @ 1300… and when i plug it back in the way it’s supposed to be my idle drops to 200… and then shuts off… like i said i have check almost everything and the only thing left for me to troubleshoot would be to put my stock manifold back on… so let me know if your blox manifold has been a problem to any 1…
well i know some folks running n/a on a blox intake manifold – nobody on boost – make sure manifold is torqued down correctly & no gaskets pinched… lightly spray w soapy water to see any manifold cracks or leaks –
did you check the vac hose off the bov? that would cause you7 to idle reallly loww n stall out
do u have a vacuum manifold or 65,000 T fittings
GE vacumm manifold…
when i first installed my blox manifold i had a idle problem, i just adjusted my idle and the problem went away after a few days of breaking it in.
