I’ll get the exact model number of mine tomorrow afternoon!
I’m slacking! I’ll get that exact battery part number today!
Wondering on that battery type. ![]()
Got the fuel pump out. Didn’t have the lift since a few friends were prepping for club racing, but the job wasn’t really that hard. Just used another fuel pump to pull the old fuel out, then smooth sailing. Will also give me to opportunity to rebuild the fuel pump/level harness.
So it looks like another member had a similar problem to me.
http://forums.g2ic.com/showthread.php?210694-VSS-Code-17
Reached out in hopes that the vss solved his problem. Bought a 12 dollar speed sensor and pigtail on eBay to go electric. Fingers crossed.
And my konis are blown… Love this car.
the stock tank has a drain plug on it, why didn’t you just use that?
Saved the fuel. Couldnt get high enough on jack stands to get a fuel jug under it.
Random updates. I haven’t messed around with the car too much. I purchased and electric speed sensor. Someone on here found my post and emailed me about the problems I was experiencing on track. He was experiencing the same on his dirt track integras without the speedo connected. I purchased an electric speed sensor and wired that to the ecu. Fingers crossed on that solving my problems.
My Konis were blown. Ordered 4 new. Unknown history on the existing ones so I’ll shelf them until I need something to revalve. Waiting to install with extended front tophats.
Threw some rollbar padding on so my wife thinks it’s safe for me to drive on the street occasionally. (I know i shouldn’t and I’ll avoid it at all costs, but for things like hitting the dyno, or heading to other shops…)
Also, the car hated idling for some reason. I pulled the intake manifold, trimmed the intake manifold gasket and double checked everything for leaks. Seemed fine. Same problem. I decided to do a valve adjustment. Felt like a gorilla worked on the valves before, but a few were out of spec. Adjusted and she purs like a kitten and AFR’s look good throughout the RPM band. It will do until I can get an S300 and a tune.
Signing up for another HPDE at the end of September and will be bringing the car home to my own garage, so updates should come a little more frequently. Also, that will be one of my last hurrah type things as our child (first) is slated to arrive early november.
Dog and konis:
Untitled by Rob Heckel, on Flickr
Difference between speed sensors… (saved weight I guess?)
Will check in again soon.
Good call on saving the Koni’s, eventually you may want to run RACE valving to run higher springs. Hopefully that VSS solves your issue - fingers crossed! ![]()
[QUOTE=billabongrob;2333671]Do you have a link to the battery? I’ve been looking at the AGM batteries for snow mobiles and maybe even lithium ion.
As for the kill switch, it will go where one of my dash vents are; either far left or far right.[/QUOTE]
Sorry man, haven’t been on in forever.
Go on to Batteries+Bulbs Website. I think mine is like Model # SLI24AGMDPM. I would have to confirm.
Went outside, started the car for the first time in two months…not even two cranks and fired up quick.
^ That’s an expensive battery!
Dropped by the dyno yesterday with some friends.
- The car seems to like the VSS I put in. No more check engine lights! Seems to be running well. Driving it on the street is obnoxious. The temperatures stay around 190 while cruising on a 92 degree day.
- I guess information on the P8R B20 is somewhat uncommon, so here’s my mods and my Dyno sheet: B20, P8R Head, Short Intake, Hytech headers, straight through exhaust, LS intake manifold, Blox thermal manifold gasket, oem injectors, Blox FPR, NO TUNE, 18 degrees ignition. Pulled max hp: 139, max tq: 135.22 (93 degrees out, and after a 30 minute drive there)
First Dyno by Rob Heckel, on Flickr
I think that this motor could easily do 160 with a proper tune. Also not thrilled about my AFR… a tune may be in order.
Dyno Video 9.21.16 by Rob Heckel, on Flickr
Made it out the track. Wasn’t as good as I expected, but I’m also a little rusty and this was the first time I have truly got to drive the car. (Kinda) Car ran good for the first half of Saturday, then it started firing on 3. Turns out an injector was dead. Drove home for the night, picked up more injectors, had to slice and dice the harness yet again. Now I have 2 obd2 and 2 obd1 injectors. Yay. Drove for around 60 minutes straight. Brakes eventually turned to ‘OMG way too hot’ and started dropping off. Anyways, here’s a little picture of me lifting the rear on stock sways.
[IMG2=JSON]{“data-align”:“none”,“data-size”:“custom”,“src”:“https://c1.staticflickr.com/6/5831/30417871312_f0de0ba6f9_o.jpg”}[/IMG2]Untitled by Rob Heckel, on Flickr
[IMG2=JSON]{“data-align”:“none”,“data-size”:“custom”,“src”:“https://c7.staticflickr.com/9/8268/29463645854_fb1f646362_o.jpg”}[/IMG2]
lift again by Rob Heckel, on Flickr
Messed with my rear bumper support. Shaved 20 lbs. I don’t recommend that anyone does this, though I don’t think it’s much worse than the JDM rear support. [IMG2=JSON]{“data-align”:“none”,“data-size”:“custom”,“src”:“https://c5.staticflickr.com/9/8553/30164411412_cb98e77382_b.jpg”}[/IMG2]
Naked Butt by Rob Heckel, on Flickr
Before: [IMG2=JSON]{“data-align”:“none”,“data-size”:“custom”,“src”:“https://c6.staticflickr.com/6/5639/30300141165_95aeb6d7d5_c.jpg”}[/IMG2]
Bumper support trimming by Rob Heckel, on Flickr [IMG2=JSON]{“data-align”:“none”,“data-size”:“custom”,“src”:“https://c3.staticflickr.com/9/8270/30003416370_d7ff95e548_c.jpg”}[/IMG2]
After: [IMG2=JSON]{“data-align”:“none”,“data-size”:“custom”,“src”:“https://c5.staticflickr.com/9/8582/30184538452_d2e6c785ec_c.jpg”}[/IMG2]
Bumper support trimming by Rob Heckel, on Flickr [IMG2=JSON]{“data-align”:“none”,“data-size”:“custom”,“src”:“https://c3.staticflickr.com/6/5693/30003413930_c793d79d25_c.jpg”}[/IMG2]
Current state of affairs
[IMG2=JSON]{“data-align”:“none”,“data-size”:“custom”,“src”:“https://c2.staticflickr.com/6/5642/30403647081_9368f45f21_b.jpg”}[/IMG2]
What have I gotten myself in to? by Rob Heckel, on Flickr
Well, I had a son so the work isn’t happening as fast as it used to. In the middle of rebuilding the chassis wiring harness to have only the things I need. The electrical parts keep rolling in. The chassis wiring is a daunting task; however, I wanted to keep the headlights, turn signals, and that’s pretty much it. Just the bits that I get it ‘legal’ and drive it around town. The engine harness has been hacked up, so there will be some repair there. Including more pictures just to show progress and the mess… Steering wheel and pedals out, etc…
[IMG2=JSON]{“data-align”:“none”,“data-size”:“custom”,“src”:“https://c2.staticflickr.com/6/5476/31344978921_b077d7713f_b.jpg”}[/IMG2]Wire mess by Rob Heckel, on Flickr
[IMG2=JSON]{“data-align”:“none”,“data-size”:“custom”,“src”:“https://c7.staticflickr.com/6/5723/31423330526_4612a26299_b.jpg”}[/IMG2]Wire mess by Rob Heckel, on Flickr
[IMG2=JSON]{“data-align”:“none”,“data-size”:“custom”,“src”:“https://c1.staticflickr.com/6/5526/31423330656_318f28cccb_b.jpg”}[/IMG2]Wire mess by Rob Heckel, on Flickr
[IMG2=JSON]{“data-align”:“none”,“data-size”:“custom”,“src”:“https://c5.staticflickr.com/6/5661/31423330756_68a574e8df_b.jpg”}[/IMG2]Wire mess by Rob Heckel, on Flickr
At this point, I’ve rebuilt the rear harness, separated the fuel pump harness, and have just pulled the dashboard harness to begin clearing it out. The main harness is undergoing surgery. A lot of pins, connectors, and crimpers in the mail now. I hope to have some updates in the near future. (Not just pictures or unmarked wires)
Nice! I did all my wiring forward of the firewall and it was a bit of a task but not too bad. Eventually I’d really like to redo the harness from the firewall back too - I’m sure there’s a LOT I can remove.
Minor update. No wires in the car at all. Got tired of trying to track everything down and decided it best if I just simplify the wiring to what was necessary.
Been working on what I’d deemed the central control panel a bit.
Gonna wire some stuff up one of these days by Rob Heckel, on Flickr
More panel by Rob Heckel, on Flickr
Control panel (in progress) by Rob Heckel, on Flickr
It’s very time-consuming; however, after I drove the car once, I decided that I liked it so I’d do things the way I like.
Wiring looks great ![]()
Picked up yet another car…
Car by Rob Heckel, on Flickr
99 GSR, single owner. Fresh-ish paint, done by acura. Head rebuilt at 140k. Currently has 212k. Mint interior, with the exception of a minor bolster tear.
That’s awesome Rob. I’m usually scared of repaints but if it was done at Acura it was probably a warranty and something that would have cost $5k or more!
Nothing too new or crazy. Waiting on a harness from CJ’s Wiring to show up, now that they have a standalone race version. I decided to hop on that.
I’m currently in the process of bending brake lines and installing an adjustable proportioning valve. Hoping to get some Antique plates and get this thing to some events soon. ![]()
Wiring Harness has arrived. Put new (rebuilt) injectors in. Need to finish up the rear lines and pressure test/bleed them. Worked on the gauge panel a little bit. Should be enough to get the car running… 2 flush mount LEDs in the top for CEL and Oil Pressure. 2 little amber ones for the turn signals on the sides of the Tach. The gauge on the right is water temp, left is wideband.
That looks great - simple and clean ![]()
