Tuning Basemap Help
ok guys i have my innovate lc-1 wideband hoked up and everything, however when i start the car it wont idle right and LogWorks 2.0 says that it has an AFR of like 22:1
i have a basemap made following the directions on xenocron’s website
i have the white and green wires from the LC1 grounded to pin A16 and the blue grounded to the floor under the ECU.
should my AFR be this high at idle with the basemap? or is there something wron g with the set up?
http://xenocron.com/te.php?page=fueltuning
You were in the right place-keep reading.
Just add more fuel…and keep trying.
Trial and error…its VERY hard to blow something up at idle.
got it working, but with your basemapper delux i have it set to 450’s with 115 boost correction, when i hit boost it is close to 13.3-14? its only a t3 .42 .48 with 3in DP and 450’s running stock WG spring 6.8psi
Set the Boost Comp higher…
