hey guys,
hopefully soon i will start getting my parts together for my turbo b18a non-vtec build up.
I don’t know as much aboout turbo as i’d like to at this point so i have a quick question about pistons. i am deciding to go with forged pistons with a dish top, but i can get ethier the ones that keep the stock compression ratio of 9.2:1 but with the dish top, or the ones that drop the ratio to 8.5:1.
the turbo kit i am looking at is by turbonetics and factory set at 8psi of boost which they say is good for a stock engine all day long. I am planning to modify the kit to run at 12psi boost for more power but i don’t know if i can run that on stock compression ratio or if i need the dropped ratio.
also if i do go with the dropped ratio, what is the max boost i can run. i will have forged rods as well but prolly the stock crank, and of course some head work done. i had heard the max on the stock block was 14psi, and i certinly can’t afford the dart block even though it is super sweet.
any suggestions guys??
