turbo help
okay ive been looking to turbo my da for awhile and i want to get a kit from a repitable company. i found one from turbonetics. it says its for the 92-93 acura integra gs/ls. heres the problem it then specifys that it is for the b18b1. i didnt think they started putting those in integras until 94. but anyway i know the block is the same but the head is a little different on the b1, would i run into any major problems when and if i tried to install this… thanx
link to the kit? b18a and b18b are the same when installing a turbo kit. the biggest difference is the intake manifold but since that’s not part of the turbo kit you’re good to go.
i think the turbo will bolt on, all the oil feed and return lines will work, just that the charge piping wont fit perfect
heres the link http://www.raceinspired.com/p-3097-turbonetics-turbo-kit-acura-integra-gs-ls-1992-1993.aspx thanks for your guys help i thought it would work
“actual product may differ from sample picture above”
DAM, I WANTED THAT VQ35 350Z MOTOR WITH MY TURBO KIT!!!
looks like good quality parts. if i had 4 g’s and didnt wanna source my own parts… seems pretty good
ight thanx guys
