Turbo Info.....
I have searched and found nothing very helpful. I just put a 20g turbo on my GSR and I was just curious what fuel delivery systems are being used other than Hondata etc. I have a Greddy Kit with an Upgraded 20g. The kit came with the blue box but I am OBD0 so it does not assist me at all. I have a 255 wakbro, 444 Injectors, Aem rail, Regulator and Apexxi VAFC. Is this sufficient for 6 Pounds of boost? I am new to the turbo world so I am trying to find out how to keep my motor from popping earlier then it need to…
Thanks
Chris
i have a T4 turbo, running on AEBS fuel rail, VENOM injectors, and AEM adj press. regulator with a S-AFC. Runnin on stock fuel pump at 45PSI.
Running 5PSi of boost. Works fine for me.
Your setup should be fine. waht HP/Tq goal are you aiming for
are you wanted to turn the boost up? i have a b17a in mine with aem fuel rail, dsm450 injectors, vafc hax, and walbro 255 in tank fuel pump, and fmu. im running 6psi everyday driving and 10 when i want to.
gunit more about ur setup???
FYI, this thread is 2 years old. Check the dates.
i got uberdata on DSM 450s and res box
