What is a good turbo manifold for a da?
:search:
i heard nawz makes a good one. its pretty expensive tho. if you cant afford it, you can go with an apc one.
I did, but no one rates or tells how the manifoids fit,look,or last. I want to purchase a blox turbo manifold, but I’m not to sure how that would fit. Im just trying to get a good manifold for my $$$$$$. I would like to spend around 250-350. Does any have a blox manifold, if so how does it fit?
i would go with a inline pro manifold
i have a ramhorn equal length manifold and it is a big hassel to make it work in my da9 it would have been a lot eaisier with a cast manifold such as the blox or inline pro just try and find something where the wastegate port is in a good location like the inline pro one
thanks for the advice gen2tegls, the inline pro looks good, but do you know if that manifold fits in a da? I dont want it to be a big project when i purchase a manifold, so I want to make sure I cover it all.
Not to hijack the thread, but I read in the sponsor section that Spoolin performance doesnt make a manifold that works with the fullcore radiator. Will the inline pro or the BLOX work with the fullcore? Im already expecting some block grinding, but still.
Thanks
MantisX
blox/ugr worklswith fullrad
Spoolin performance manifolds will but its depends on which manifold you get.
