Ok i checked out some manifolds from different places and some of the manifolds for my car had the manifold with the place for the turbo to mount to and also a tube going upwards with a football shaped piece which a asumed was for the wastegate,correct me if im wrong, some other ones didn’t have that on the manifold, Whats up with the two different styles, which is the better one, or does it depend on my turbo setup…
Yeah, that’s the external wastegate adapter. The one’s that don’t have it typically are for systems that use internal wastegates.
The internal wastegates are better for the environment, which typically don’t go hand in hand with performance. Most high output Turbo engines, use externals. HTH.
does anyone know which guy from Canada i believe was making custom manifolds, What about South Florida Performance, they make them too? Just wondering how to get a hold of them.
i wanna know too
member MIKE.
This is by far one of the pimpest turbo manifolds I’ve seen from John @ Hy-tech. It also has a water to air intercooler, you can get them from Vortech or make it yourself like this guy did.
