Turbo + Nitrous Set-up
Who is running a turbo and nitrous? I am currently running with a T3/T04E on a B18C1 with ITR internals. I runn 12psi on the street and 16psi at the track. I have a NX dry kit that was left over from an old project that is sitting in the corner collecting dust. I am thinking about dusting it off and installing it with the smallest jets I can find. I would be using it for off the line to help the turbo spool. I have found 35 shot jets. Is there anyone running this set-up in here? How has it work for you?
Well what sized(Compressor and Turbine sizes would help) turbo is it?
You could run a small shot with no problems however Type R internals are not particularly ideal for high hp and tons of FI pressure (the combined force of the turbo and the nitrous) but it is really ALL in the tune and timing specifically.
If it’s a small turbo you really shouldn’t need much help spooling it up and it would most likely create more traction issues. Also I don’t see the need to help spool it up even if it’s a 60-1, 35R, SC61, etc, something in that range because it also shouldn’t need it. With anti-lag and some slicks you should be fine without it.
They only guys running a shot to spool up their turbos are guys running something like 72 mm turbos with HUGE turbine and compressor housings.
