Turbo on stock internals?
The dealer is fine… You can probably find a little bit better of a deal if you search on some of the online part stores…
I doubt your pan is bad, its probably the gasket, improper installation of the gasket originally (make sure to clean the bottom of the block well) or its the oil drain on the turbocharger drain.:hugs:
Well the car isnt turbo yet…
so it could either be the gasket or the pan itself, but whatever it is its starting to leak badly and i need to figure it out asap.
replace the gasket first before replacing the pan (highly doubt its the pan).
And for the headgasket, just go to any auto parts store that carries them. I think they are about $60 for the headgasket and 120-130 for the full set.
www.oemacuraparts.com save yourself some money
yea but if your like me and hate waiting for your damn parts to arrive, i’d just hit up autozone/advanceauto
but if you dont mind the wait and want to save a few $$ then acuraoemparts.com would be your best choice to shop.
Awesome thanks guys,
I get paid thursday so ill hit up autozone or something and get the oil pan gasket.
Also, i think the crossmember under the oil pan is bent and is causing the exhuast to hit the pan…
I think i bought a lemon, but wtf ever…
Why direct him to acuraoemparts.com when www.oemacuraparts.com it’s much cheaper usually comparing same parts that is.
I been using this for some times now.
For an Example on the type-r anti-swaybar i get mine there cheap.
ITR 22mm Swaybar
52300-ST7-Z01
@acuraoemparts.com=$71.22
@oemacuraparts.com= 97-01 ITR Listed / Stabilizer bar, integra, 2 door, type r 97-01 $66.77
So basically you have to do your searching to save. Like me Do all ordering one time for great shipping.
Headgasket
12251-PR4-004
@acuraoemparts.com=$57.62
@oemacuraparts.com=$54.02
Oil Pan gasket
11251-P30-004
@acuraoemparts.com=$21.32
@oemacuraparts.com=Only 94+ LS listed $19.99 all same part number same fit.
Now I hope for some of you that PLAN to do online OEM shopping this is the place to go.
For the ones that’s been ordering elsewhere, you’ll probably change your mind now.
Say bye bye to the old faithful b18a, headgasket went…
ditching it for a b17 :jerkoff:
are you going ls/vtec turbo?
oh yesh
[QUOTE=DClark3one3;1861625]Say bye bye to the old faithful b18a, headgasket went…
ditching it for a b17 :jerkoff:[/QUOTE]
b17 FTW:rockon:
