i just recently instaled the greddy turbo timer, and im trying to set it, it wont go past 1min and 30 sec. when i first played with it it went to 10+ min. i have un hooked it, un hooked the battery and still same effect. any one have this issue?
bump
those things are a pain in the ass to fuck with because greddy made it all gay, you have to push the 2 buttons at the same time and itll shut off if you dont or change modes or go to five thousand minutes and stupid shit like that :gay: sell it and get an apexi or HKS
I agree, I also ahve the Greddy turbo timer and it’s a BITCH to use. Have to press both tiny buttons at the same time it’s a pain in the ass, luckily once it’s set, you generally don’t ahve to touch it… WHat exactly are you trying to set? the preset countdowns? that n1min 30cseconds sounds like the minimum value you set weather the car has been running for 1 minute or 4 hours. in which it starts the countdown from there and not 0 seconds(for auto countdown)
im trying to set the count down presets. so far i have pressed every combo of buttons and all i have seen is count (a). i hit time and it goes 0.00 0.10 up to 1.30 then back to zero. i want to set the countdown for 3 min.
i think thats the minimum that it will go until you start driving the car…then it will adjust to how far youve gone…
I have one on my Talon, what you have to do is when you switch through the different modes, it will have P1 and P2 on mine P1 was the low setting for driving normal, and light boosting, once you toggle the buttons around stop on P2 and program it for 3:00mins, so then the timer has a Hi/Lo setting! So when you drive hard and have been boosting alot, just change it to P2! It’s retarded and stupid, my instructions came in japanese and I had to get the online PDF file, to figure it out, I said screw the whole handbrake system, and throttle speed sensor!
see thats the thing, i have yet to see P-1 or P-2 the only thing i have seen displayed is -L-,Sid,off, and the 130, nothing else! its really fustraighting i hold time for like 20 secs. nothing no beeps or anything, hold both down no change, but if i tap the time it will move but only to a min 30? :mad:
bump…anyone? im about to drive it up to central florida turbo and let them figure it out
