look at it this way without a LSD if you break an axel the car wont move since you will have a open diff and the broken axel has no resistance BUT is you do have a LSD if you break an axle you can still move the car to get to a place to fix it since it powers both wheels regardless of traction just like a posi-trac or locker would except it will slip in turns
good point
i think im gonna get the y1 with the lsd, and an act 6 puck, does anyone know about xtd clutches? i was doing some searching and found them on ebay, didnt know if they were any good
are you going to test it by installing first? that’s the only way to see if it’s grinding without taking it apart. you may be trading your good tranny for a grinding tranny…
make sure it has the stinking lsd in there! no rod in the hole.
gm syncromesh fm may help with a slight grinding.
well im gonna keep my old tranny and put in the y1 and test it first
