after finnishing installing everything, minus downpipe to exhaust & dumptube, my wastegate i have right now has a 16 or so psi spring… and im only looking to get the 5 - 7 psi spring… so that was big problems… i felt so scared when i saw the gauge go that high…
anyone have any clue where i can find one? only place i’ve found the spring alone was on some no-name shop i found… so anyone know any places in the bay that may have it in stock?
How high did the boost actually go, and are you tuned and still on the stock MAP sensor? If you’re on the stock MAP, tuned or not, I wouldn’t go into boost at all until you straighten that out. The stock MAP sensors only read to 10 psi and some change, so things get really lean after that.
I wish I could help you out with the wastegate spring, but I’m internally gated so I haven’t looked into them at all.
