After doing the conversion using awalp’s walk-through, I ran in to some issues that many others seem to be having. This isn’t because his walk-through is bad, it actually seems to be because superbrightleds.com possibly changed their 74 to a new style or something and it no longer works for some of the things we needed it for.
I came up with a solution and decided to post a new thread about it that is more up-to-date, since a lot of users seem to be having issues with the 74 bulb. This walk-through covers 90-91, I honestly do not know if the 92-93 is different in any way regarding the cluster/climate controls. I will not discuss the removal/installation of the climate controls and cluster, but I’ll be nice and post links if you don’t know how to remove/install them…
Cluster removal-
http://g2ic.com/forums/showthread.php?t=188011
Climate control removal(fix your solder joints while it’s out!!!)-
http://g2ic.com/tegtips/interior/7.html
You will need to order the following bulbs, I recommend superbrightleds.com because after over a year I still haven’t had any bulbs burn out other than issues that were un-related to the bulb itself…water damage, etc. I do not cover the dash-switch lighting…I’ve never pulled them apart, I have no idea what bulbs they take, I have no idea how they’ll look with LED bulbs. When I get the time I’ll grab a spare set of switches and toy around with them, maybe come up with a guide on how to fix them if they don’t light up, and convert them to LED.
2 x 194(circled in blue in my pics)
4 x T1.5(they come with sockets, circled in red in my pics)
4 x 74(circled in green in my pics)
Get them all in WIDE ANGLE, and I don’t recommend getting the high-power LEDs because it would be obscenely bright and quite a bit more expensive. It would also do a really good job of showing up as un-even lighting…let’s face it, the lighting already isn’t even across the cluster and when you go to an insanely-bright bulb it shows more. You want it looking nice and clean, so go with the normal LEDs. I personally went with blue on both of my conversions, but you’re free to pick whatever color you wish…amber seems to be pretty popular and looks cool.
Here’s the bulbs that you’ll need to replace, I’ve circled them in various colors which are listed above for identification purposes. I didn’t get a picture of my fan-speed/temp-mix controls to show the bulb…but the bulb is actually part of the control-panel, you can see it on the wire in the third pic.
Back of cluster-
Top of cluster-
Climate control panel-
Just replace those bulbs with the ones you ordered, matching the colored circle in the pic with the color listed with the bulb types above.
***The T1.5 bulbs will be a snug fit in the top cluster lights, but nowhere near as bad as re-using the OEM sockets with the 74s in them. In my second pic you can see that the right-side of the PCB is broken…I tried to use the OEM socket with the 74 bulb, it wouldn’t fit so I tried to force it and that’s what happened.
***The climate control lights use 74s so that will also end up being a snug fit back in to the controls, worst case scenario you’ll have to use a knife or razor blade to bore out the socket a little bit so the new bulb fits in it without expanding the socket causing the socket not to fit back in it’s spot.
***For the green circled socket in the first pic, the 74 may fit a little loose…look inside the socket for the tabs, bend them towards the middle with a small flat-head screwdriver or something like that, this will tighten up it’s grip on the new bulb.
***Again, be sure to REFLOW YOUR SOLDER JOINTS inside the climate controls while you have it out of your dash. This fixes the “buttons don’t work/lights don’t work” issue that almost everyone has with them. It’s super easy, and is detailed in the walk-through I linked above. Removing the climate controls is too much of a pain in the butt to have to do it twice!
Pics of my cluster coming shortly, car is currently on jackstands with no motor/trans, should be done Wednesday-ish. Until then, enjoy the pics of my first conversion before I ran in to issues with the 74s, and before I converted the climate-controls.
I will not be held responsible if you break anything, do this mod at your own risk. Thanks to awalp, G2 Racer and Brinks for their awesome write-ups. :rockon:
