under WOT around 5000RPM’s I can hear a loud ticking. Kinda like when you tap the tip of a screwdriver flathead to a metal, probably 10 ticks a second.
I have read from a magazine that detonation will sound like a marble inside an empty soda can.
I have tuned the car and from 4500 to 6500 my air fuel ratio is steady at 12 - 12.5
how much timing are you running in that area? what is your peak timing? what heat range plugs are you running? run at least a 7, you can run 7-9. when tunning, I run 11.8-12.2a/f but never higher. you might wanna richen things up a bit.
P.S. if your valves hit, your engine stops running. then you have to pull the head and replace the bent valves.
As for the graph I have no idea why i have more TQ than HP, I never heard that it’s impossible to have more TQ than HP.
But anyways when I got my car tuned i was running 94 octane and then after that I’ve been using 91 octane. Could this be it? I will try to empty my tank and fill up with 94 and see what happens, thx
Yeah, you’re right, that’s some serious mis-information there. My '99 Chevy S10 came out of the factory with something like 240lb trq and 175hp. I miss that truck… :burnout:
he was prob. saying it is nearly impossible to make more torque than hp on an LS. IMO you have a seriously hurt engine, or a seriously SHITTY tune. that peak in A/F at 4100 is no good.
I have tried to use 94 octane instead of 91 octane (thinking I can get away with it since gas is expensive). Then no more detonation!
I would have known since my car was dyno tuned under 1/4 thank of 91octane and 1/2 tank of 94 octance…
I have also found out why I was smoking really bad under high temperature. The exhaust side of my turbo is leaking oil hence the pale white smoke. Time for a new turbo, but that’s next yr.
