Seriously, just stop posting your lazy nonsense.
Hacking mine up today! Theres a difference between laziness and easyness… of course its BETTER to do it the right way…but im not laying in snow in 20 degree weather wen i can cut and hole under the seat…
OK good luck cutting the holes in the body to access the fuel pump! you can only see the sending unit from inside the car.
my 91 integra gas tank has a rear drain plug, empty your fuel n replace after
drop your tank, replace your lines/straps
dig out the fuel pump, careful not to let dirt inside
you need zip ties because the walbro is smaller then stock and won’t fit in the stock bracket without being zip-tied to it
preferably have a wire tool and proper connectors to reconnect the wires
this would be a great time to replace your fuel filter under the hood while the fuel system is disconnected
also after you have the walbro installed test it before reinstalling the whole tank again by turning your key ahead to make sure it’s pumping, becarefull where the lines are pointed learned that the hard way
if you can’t pull this off or don’t have a garage to do it in i would highly suggest bringing it to your nearest decent shop
my 3cents
its a 300$ car with so much rust u can see the road inside the car…however after actually doing it i wont do it with my good DA when the day comes
