I posted in another thread that I just programmed a new chip for my injectors to run at 14psi. Well everything was fine until later on that day the upper intercooler piping popped off. I put it back on and realized that when i get to 10lbs of boost it pops off. It comes off from the intake manifold. I thought of everything possible. I thought maybe the coupler was worn so i changed that, and that didnt help. I tightened the bracket i have holding the intercooler pipe steady and that didnt help. Has anyone else had this problem?
First of all. Your thread title sux and I’d be surpised if teh mods don’t modify it themselves or lock this.
second. try using stronger clamps such as T-bolt clamps. If that doesn’t work. then get a lip welded on the edge of the pipping so the couplers won’t blow off. Or bead roll it.
http://www.g2ic.com/forums/announcement.php?f=18&announcementid=13
USE APPROPRIATE SUBJECTS
Your subject should be a broad description of what your problem/question/topic is. For example, don’t post a thread with just “HELP” or “QUICK QUESTION” in the subject. Doing this will be regarded as pure laziness and the thread will be promptly deleted. Using appropriate subjects helps the search engine function better!. Also, do NOT use a different subject than what your thread is about, just to get attention. It will also be deleted.
