I have these two fuckers just hanging out. They obviously make vac leaks, and I would like to take care of it. What should I do, what did the other boosted teggers do?
Thanks guys
BTW, I am boosted, and those things are not attached to my intake, thats why I am asking .
I just dealt with these issues on Wednesday when I turbo’d my DA. Thanks to this piece of shit blown turbo it didn’t last very long.
Anyway, “fucker #1” I removed completely from my intake manifold. I think it was two star screws and a little plastic tab on the throttle cable rotor. Pulled it out, threw it out, no adverse affects at all. As for “fucker #2”; just pull the vacuum hose off of it and cap it if possible. I also removed the selenoids located directing behind the intake manifold which were routed to the map and fpr. Now my fpr and map sensor plug directly into the intake manifold without any obstacles.
What exactly are those two things I have them hooked up on my turbo integra but the only engine check light codes I get are the #1 oxygen sensor and #13 Barometric pressure. I have only owned the car for a month and am still reading through the repair book.
wow just wow. If you dont know what it does why are you posting?? Yuri if you carefully remove and unscrew them you might be able to sell the here , on ebay , or on Honda-tech. The “cap” (youll see what i mean who you remove them) fits some other honda manifolds.
