plz plz plz someone answer this ASAP. what do i do with all this plumbing thats in the way of where my intercooler should be mounted.
Idont know what the top one is but the lower one is the PS cooler.
Two options pull the power stearing or just pull the cooler and loop the lines that go to it.
the top one i think i could move but the bottom ones wont. so if i pull them then i wont have ps? i could just remove the whole system and thats that?
i took all that out… but i dont have ps, or ac any more
I took out all the AC lines and the PS line I unbolted the bar from the latch and put the PS lines behind it and bolted it back up IC fits perfect like that.
Yeah just unbolt the vertical bar and bend it back behind it and bolt it back. Frees up plenty of room without sacrificing the coolers.
MantisX
pics of it plz? i need help with this bad. i wanna just bend it up like you did. maybe you could even photoshop this or draw on where you bent.
not super great of a write up but basic enough to work.
mattv- thanks alot man. im going to have to try this out. it seems like the best way to do it instead of removing all of the lines. do you have a pic of it done on your car?
i just removed the cooler completely and used a hose to loop the lines where they feed into the cooler, the system can function fine without the cooler
Unfortunately I only took a pic on my phone after the IC was mounted :\
thanks alot man. as soon as the headgasket gets in ill post pics of how it went. thanks alot again mattv
what did you with your radiator fan? i bought a half sized and was wondering what do i need to do to get my stock one to fit on there. also which fan would i use? thanks
I was able to keep my full rad and fan so not too sure on that one
were you? could you post pics of your set up?
Here is a pic of my manifold and WG
nice…
i would suggest 2 slim fans, one in the front of the radiator and one in the back. push-pull method.
it looks like that manifold only kept one of the fans on the full radiator.
