Instead of getting a new motor like i was planning on, i decided to build the LS. It needs new rings so, for my new set up tell me what u think the power will be. Will i be safe running 20psi on that? I have seen people run 14psi on the stock LS on a 60/63. Will i hit 400?
8.6:0 pistons, not sure what brand
rings
Arp heastuds
MLS head gasket
stage 3 clutch
t3/t4 70/82 turbo
Air-to-Water IC (complicated setup but i got it figured out)
2.5 in DP
I wouldnt run a c/r that low, it will be too laggy before boost. And yea, that turbo is a little overkill. That combination will take eternity to build boost.
