I’ve got a b17 i wanna know your suggestions on different combos. or what has worked for you. this isnt my first build either. I’ve built 2 other boost set ups. An ls that made 427 whp, and a d16z6 that made 314whp. Just have never seen a turbo setup b17. thanks.
Its hard to find aftermarket rods for the B17 due to the screwy rod length. I don’t know any off the top of my head, but I’m sure they’re out there.
i have never seen an aftermarket rod for the b17a. and if they did exist this would be the first site to that information. you might be out of luck i’m afraid. maybe if you contacted a rod manufacturer such as eagle or manley they can custom make some? i would imagine it being way too expensive though. how ever piston choice isn’t a problem.
http://www.raceeng.com/p-7170-crwr-billet-rod17b17a191-93.aspx
Word is, Crower is the only company to sell off-the-shelf rods for a B17. And for $750+? Ew.
Unless you’re going to boost, its not worth it. Get the stock rods shot-peened, stress/beam relieved and reconditioned, throw some ARP bolts in there, and call it good.
Yea I’m pretty sure Crower is the only ones to make. teggyguy has a set for his all motor build http://forums.g2ic.com/showthread.php?200932-Teggyguys-molasses-build-thread&p=2132721&viewfull=1#post2132721
damn that’s expensive for off the shelf rods! i guess that’s what it’ll take if you want to have a forged b17 block.
yes your right crower is the rod thats my fault for that question. what kinda pistions? Im shooting for 20-25 psi on 91. im lookin for like 9.7-1 compresion
any b16 piston will work. JE, CP, wiseco etc.
