What needs to be fixed on your integra??
On mine i need to fix, at 152,000 miles
  1. Exhaust leak.
  2. Leak under the hood.
  3. Alternator.
  4. Center console.
  5. Bushings.
  6. Main relay.
  7. Fog light wiring.
  8. Tie Rods.
  9. Ball Joints.
  10. Clutch
  11. Tranny
  12. Rust in rear quarter.
  13. Oil pan.
  14. Dent in driver’s side door.
  15. Paint job.
  16. Front seats.
I think thats about it. lol depressing :worry:
But I love my car!! :rockon:
So what needs fixed on your integra’s?? :read:
Windshield
Hood
Pass fender
Minor rust on pass quarter panel
Minor rust on trunk lid
Speedo cable
Fuel door cable
Trunk release cable
Hatch shocks
Tail light gaskets
MFR
Approx 335xxx KMs
I think that’s about it, other then rewiring my audio system (but that’s optional so that doesn’t count)
^^^ post your mileage!
off the top of my head…
90 integra xsi b16a w/ 88xxx kms
  1. left front steering rack boot.
  2. Axle Shaft boots.
  3. Oil pan Gasket (Minor Seep)
  4. P/S hose (Minor Seep)
My car’s overdue for a timing belt–that’s about it.
My windshield is cracked (hit a deer + minor fender bender, both in 2001), but that’s not going to be replaced; at this point I only address issues that actually serve to keep the car on the road.
DA9 197k miles
  1. starter
  2. right lower ball joint
DB1 219k miles
  1. Swap power steering rack
  2. tighten header bolts to “Y” pipe
  3. Timing Belt & Tensioner
  4. Blower Motor
  5. A/C condenser fan
  6. Release Spring on the clutch pedal
  7. Transmission and rear torque mount
I have all the parts besides the new starter in the garage…but who has the time??
136,xxx miles
1.header leak
2.heater (only works on high)
3.dent on front driver side fender
4.dings on both sides
5.slight leak from valve cover
6.front bumper fitment (92-93 on 91 LS)
7.driver side axle
DB1
174k miles
1.both cv joints
2. trunk
3 filler under trunk
4.tint
5.paint
6.clutch cable
7.springs
8.water leak
9.oil leak
10.vc gasket
11.head gasket
12.exhaust leak
13.fix a/c
14.steering gear
that’s about it I think.
there’s no point in me posting my own list because every list posted is pretty much exactly what i need fixed… ahh i can feel the love
Window
Shocks
Random creak by drivers wheel
Tie rod ends
Paint job
paint
rear bumper
oil pan leak (again)
traction bar
rear camber
needs new carpet
all window seals (bish leaks when it rains,just found out lol)
turn signals
turbo oil leak
cluster f**k of wire under the dash
and the ecu
92 da 203k
187000kms.
driver door.(Rust)
brakes.
master cylinder
rear wheel bearing driver side
windsheild
passenger window motor
thats it the car is a 91 GS
i might pick up a new project tomorrow its a white 92 b17 GSR
needs work tho
220 000 kms
needs driver side quarter panel
trunk lid
brakes
passenger seat
radio
oil pan gasket
timming belt
VC gasket
altornator and belt
all the bushing and a rear driver side shock…
MIGHT SAVE ANOTHER DA LOL
motor
trunk leak
passenger leak
1 - oil pan gasket … AGAIN. shoulda gone OEM the first time
2 - front pass side lca or uca, one of them is bent a bit i think
nothing really wrong with my car :smiley:
266k
crack on windshield
minor leak in head gasket
vtec solenoid gasket
crossmember
pass axle
driver side fender
pass. door panel
tranny n clutch
speedo cable
foot rest next to the clutch pedal
and code 20…lol
DA9
150xxx on shell
80xxx on motor b16
both rear control arms
radio
need a new battery
183K on chassis, unknown on b16a
replace friont windshield
fix my motor mount, bolts snapped
replace blown front illumnia
fix driverside window rattle
all i can remember so far.
106k miles.
Driver cv boot
something with my a/c
140k
cowl leak
power antenna
oxidized paint
140k motor and chassis
  1. axles
  2. shocks
  3. minor body work and a full paint job
    thats it for now…
Girlfriends DA (my old one) 204000KM
Both CV boots and shafts
Squeaky hatch
Rusty hatch
Leak that causes spare tire well to fill with water
Exhaust leak
1/4 slight rust
