What needs to be fixed on your integra??
I found out one of my rear mount T bracket bolts that goes into the transmission some how managed to back its self out and is now missing:shrug:
189K miles
Front and rear seats, (need cleaner 1s)
Better paint job
Better clutch, (but the 1 i got fine)
Timing belt
Tune up
Axle
upper ball joints
Camber front & rear
Idunno what else i need…
340xxx kms body and original engine
Needs:
new paint
new engine (currently runs perfect no leaks and burn no oil, but needs more power!)
new a/c pump and recharge
new tranny (has bad play, most likely needs new bearings)
front/rear engine mounts shot
rear trailing arm bushings are shot
driver side e-brake cable snapped
remove window tint and get new side windows (has deep scratching from the tint)
speedo cable
squeaky clutch
random creaks from front dash when driving
New battery, mine is leaking/corroding like hell
RUST!!! :worry:
I think thats about it… for now. Despite all of this I still love my teg!
re-build b17
Fix leaking gas tank
new full coilover suspension (sick of my tokiko sleeves/struts)
paint engine bay
fix broken studs for the header
think thats it…
Probably not lol
My db2 has 221k miles on her.
I need to…
rebuild the engine
rebuild the trans
repaint the car
get the body work done
get a newer steering rack
replace all the bushings
fix my trunk leak
fix the dim foglight on one pieces
find where the short is that causes superfast blinker (lights are good)
Fix exhaust rattle
dye the carpet
replace balljoints, tie rods
refinish the hood
fix leaky lights
get rid of shifter that is hitting exhaust
that does not include the mod list…
My db2 has 240K, replacing all the bushings was one of the things i forgot.
DB2
small crack in windshield.
ANNOYING rattle coming from the shifter.
passenger side seat belt doesn’t always retract.
plastic cover on the bottom of the hatch is falling off.
rear suspension squeaks.
NEW TIRES.
replace driver side bulb in JDM one piece headlights.
reinstall AC/PS.
I’m sure I’m forgetting something…
Fixed the suspension squeak. Its was the bushings on the rear trailing arms. WD-40 works wonders.
DA9 184,000miles
windshield
almost everything electrical
hatch latch
brakes
need new battery
loose exhaust
mirrors
LOTS AND LOTS OF RUST
just got the car…besides the probs…LOVE IT:rockon:
Where to begin?
Almost 300000mi on chassis, unknown on engine(swapped due to origional engine failure(spark plug froze in head))
  1. Water leaks in all the usual places
  2. Transmission leaking and grinding
  3. P/S rack won’t hold pressure (no P/S for now)
  4. Engine leaks lots of oil
  5. Rear camber arm bushings fell out. ( DO NOT BUY RUBBER bushings for this part, find polyeurathane!)
  6. Cracked body welds
  7. Body damage in right rear
  8. Clear coat nonexistant
  9. Power window slider brackets
  10. I think i might need to replace the driver too.
226k miles on chassis and engine,
  1. New windshield
  2. rebuild or swap engine due to rod knock =[
  3. new full coilover suspension, skunk2 coils with blown shocks fail.
  4. complete bushing replacement
  5. fresh 2stage paintjob with body work
  6. fix all water leaks ugh, so lame.
thats pretty much what i need to do with my car for it to be where i want it.
then everything else is all icing on the cake, i.e. seats, turbo, rims, etc.
-karlo
Lower ball joints & Outer Tie Rods on the DA9
Tie Rods and struts & heater control in the DB1
90 DA9
at 190,xxx miles
New Paint
Driver Fender and door
Driver axle
Parking and Headlight Switch
Passenger Fog Light
Piston Rings
Air Intake
Plug Wires
Distributor
Sunroof Motor
Exhaust Leak
Injectors
New Carpet
Radio Dash Kit
All New Hoses
I’m sure theres much more thats just all the things i can think of so far
1992 DB2 60K
Needs nothing other then a set of new OEM in box charcoal color floor mats… I am not asking for much. :slight_smile:
1993 DB2 @ 156,xxx
Speedo cable.
Shifter bushing.
RTA bushings.
Paint.
Eh… that’s about it.
93 DA with around 130k on body and 55k on jdm motor
-lets see…front axle boots
-4th gear syncro is starting to be a problem
-i think maybe my rear strut mounts need some attention, ive got an annoying squeak back there
-B&N short shifter needs new bushing, pain to shift
i think thats it!
93’ rs with 270k on motor and car
Paint
carpet
most of the exterior trim
exhaust manifold back
anything made of rubber
some dents
motor mounts
that damn ebay intake
auto seatbelt
'92 GS-175,000 mi.
need to repaint (faded…milano pink ftl)
new head unit (lights went out on current one)
re-wire pass. headlight (f*cked up wiring=no pass side lights)
replace stock motor (slight rod knock)
replace suspension (tein s-techs on blown shocks)
replace header (cheap ebay with a crack)
pass side axle (torn boot)
motor mounts (worn out, already have innovative mounts in the closet)
used stage I clutch (already have new exedy stage I in the closet)
shifter bushings (have ES bushings in the closet)
replace exhaust (no name muffler that came with car and 2.25in. piping)
put “H” badge on hood (corroded spot where i pulled the “A” off)
replace windshield (big crack on driver side)
new window tint (bubble at the bottom of rear window)
replace window motor (driver side is reeaallllyyy slow)
replace tires (bald azz falken azenis)
Bumpin’ the ol’ thread
I need:
Mechanically:
-Power Steering pump & return hose
-rear trailing arm bushings
-rack & pinion boots
-rear struts
-rear tires
Cosmetically:
-new front bumper
-passenger fender
-respray back bumper
Some of the mechanical things are being fixed this week.
What I have had fixed:
-motor and transmission mounts
-Antenna mast
-Idle Control Valve
-hoses
-had rear bumper pulled out after hitting a concrete pillar outside my driveway
-other little things
^this all cost ~2,500^
ne one in socal have ne db parts for sale need alot or does ne one knoe where i can get ne ??!
list of wat i need
door pannels
cup/coin holder
hoodbra
rear fog light
parking pole
rear n front seats
or just let me know what u have you guys can email me or aim me my email is masterflymoney@Yahoo.com n my aim is d1nonlyfrancisco
Blower motor, inside driver door handle, driver window, new bulb for fog light and tailight. still runs great though
