What needs to be fixed on your integra??
[QUOTE=DA9_GSR;2147894]ne one in socal have ne db parts for sale need alot or does ne one knoe where i can get ne ??!
list of wat i need
door pannels
cup/coin holder
hoodbra
rear fog light
parking pole
rear n front seats
or just let me know what u have you guys can email me or aim me my email is masterflymoney@Yahoo.com n my aim is d1nonlyfrancisco[/QUOTE]
Make a thread in the Want to Buy section asking for this, not here.
body work: rust around the back window and small dings here and there
Paint: some shiny factory green would be nice :slight_smile:
some cf parts that should be arriving soon from isport :slight_smile:
install the rest of my sounds: RF p850.4 amp, alpine m650 & 12" type R
install the rest of my suspension stuff: full-race traction bar, st sways, f7 lca’s, neuspeed lower tie bar
install msd stuff: sci-L, BTM, 2step & external coil
install fluidyne rad. & 12" slimfans
way down the line:
wire tuck, rebuild spare LS 2.1 stroked with a new and bigger turbo, and more :smiley:
stuff already done:
cf invader hood
GC coilovers on tokiko blues changing to koni yellows soon
volk gt-n 17x7 and volk te37 17x7.5 on the side
type r style lip with cf JDP on the side
DB8 sideskirts
keyless rear handles
stock LS turbo w/ac: aem fuel rail, aem reg., B&R fuel feed line, skunk2 cam gears, precision 525cc, tial bov & wastegate, blox IM, inlinepro ss mani, turbonetics t3/t04e, custom 2.5" DP through gutted cat. to Greddy MX muffler running @ 8psi tuned on crome/ phearable.net
retrofitted JDM one piece lights
s2k clear sidemarker (got over my JDM amber ones)
P/S removed
drilled & slotted rotors, ceramic pads, goodridge ss lines
need a paint job
front bumper support and bumper and bumper lights
alignment got some toe on all 4 tires
need ball joints
need rta bushings
need new muffler and piping
ac needs to be checked
need a b20 ps pump o and
needs new steering rack
need new mfr
About 151K:
-Small rockchip in windshield
-PS hose (have it, just not on yet)
-Oilpan gasket ( not a baaad leak at all though)
  • Passenger door ( have a perfect one, just not on yet)
    -Remove non-working cruise control, but I hate cruise anyway
That’s pretty much it, most everything is reaaallyy solid.
Just lotts of future mods. Taking my time :slight_smile:
I’m currently at 187k. My RS needs:
-Motor mount bushings (installing this week)
-Paint job (might go with championship white)
-New suspension setup with new bushings (rear end has a top hat squeak)
-Wheels refinished
-Minor exhaust leak fix (loose bolts i think)
-Fix the couple dents.
-Driver’s side seatbelt slider
And that’s just to make it “perfect” in my own eyes. haha
I would have an easier time of listing what doesnt need to be fixed LoL. I picked up another Integra about 3 years ago with hopes of doing all kinds of shit, all i have done is move it out of the way in the garage a few times hahahahahaha
but really it doesnt need much to go down the road, the front bumper isnt hanging right cause of a bent core support, once i get that fixed i would drive it again, just gotta find the time :frowning:
J
  1. cruise control, don’t know whats wrong with it. didn’t work when I bought the car.
  2. abs rattles like crazy so I had to shut the mutha up, unplugged it, don’t know what I’m going to do with it. I’m gonna either leave it or delete it.
  3. alignment
  4. replace all rubber boots and bushings w/energy suspension
  5. motor is high at 246xxx gonna replace or rebuild
  6. both fans don’t work EDIT, THEY DO WORK WHEN AC IS ON
  7. passenger side leaks water under dash
  8. rear shocks are out EDIT, ITS NOT THE REARS, ITS THE FRONTS
  9. oil pan gasket EDIT, I GOT THE NEW HONDA OEM OIL PAN GASKET, JUST HAVN’T INSTALLED YET
  10. new clutch, don’t know what to go with, either excedy oem or stage 1 w/fidanza flywheel
my power steering doesn’t help me turn hahaah. i think it needs fixing.
and my ABS light comes on.
  1. A/C Recharge
  2. Tranny Leak from somewhere???
  3. RTA Bushings and all front bushings
  4. New Struts and springs(car has 320,000 miles and rides rough)
  5. Whatever is causing my car not to fire up when the engine is cold(not MFR)
  6. New Radio(doesn’t work)
  7. Secure my speed cable
  8. Horn and Cruise Control
  9. New Clutch Cable
  10. New front engine mount
  11. New Driver’s side fender
  12. New muffler(hole in exhaust)
  13. New fuel filter
  14. New valve cover gasket
  15. Clean IACV or fast idle valve
  16. Fix bulbs in climate control
  17. Pop the hood and secure everything down in its original position that it was intended to be in)
wow 320,xxx miles, I should wait and see if I can catch up to you then before rebuilding or swaping my engine out:rockon:.
The engine has been swapped out… haha… I bought the car with a bad engine for $700 and put a 95 b18b1 with 30,000 miles. The suspension is wore out on this car though
1 Aircon recharge
2 Top wishbones and ball joints
3 Bottom ball joints
4 LH outter c.v. boot
5 Rear pads and discs
6 Sump gasket
7 Full body Repair + respray
8 Gearbox bearings
9 New floor mats
10 Boot door struts
and probably many other things
A/C!
the pump went out three days after i put my new engine in. :mad:
1992 integra ls
226,856 miles
*** nothing!!!
91 integra RS 290,582mi.
needs paint
needs a new radio
  1. Axles and lower ball joints - going to pick up/order today
  2. Tires - Ordered 2 weeks ago, still haven’t arrived!
  3. Alignment - awaiting tires
  4. Left corner light - broken clip so it keeps falling out
  5. Suspension could be restored (Rust)
  6. Body work (dents and rust) and paint
paint job with new radiator support
tail light gaskets
power steering hose
cowl leak
and just today the a/c vent controls
Redoing the interior now, almost all of the trim is prepped and painted waiting to go back in.
Moog tie rods, and wheel bearing should be arriving in the mail any day now.
need to strip and repaint or do something with the valve cover
SS brake lines, new blanks and better pads
Bushings all throughout
and do something with my exhaust its rattling sometimes which drives me crazy, and PO punched two holes in the back hatch to tie it up with what looks like speaker wire, And it wasnt quite run right here is a pic. I have to do something with this soon as the rattling makes me want to drive in the ocean
You guys think i can get a muffler shop to route this correctly?
92 DB1 RS 84k original miles.
-Rear driver side window (can’t roll down)
-All motor mounts
-Shocks
-Exhaust leak
-Dents and scratches
91 GS with 240k
-loose steering at highways speeds. Need to adjust/tighten the nut on the rack
-passenger side axle
-All motor mounts
-All bushings expect for the rear trailer arm bushings which was replaced couple of days ago.
thats about it for 2013
