92 AGP DB2 GS-R 239k
-needs paint
Need a new clutch got me a new stage 2 coming in this week along with shift linkeage bushings
I ran over a semi truck tire on the highway the other night so now I need to fix my bumper, lip, fender, and replace my axle that got ripped open
Rattle coming from my exhaust in the front of the car, new tires and alignment.
suspension suspension suspension. Enough said.
it would be easier for me to name what doesnt need done.
My car is an automotive oncologist’s nightmare.
Need to raise my header I have a 1/4" of clearance. Yes, raise the header not the height of the car hehe.
I just cant get rid of these stupid little oil leaks that are preventing me from my dyno time :bang:
Everything
Radiator support frame
O2 sensor, flashing oil light and I know the oil is only a couple of hundred miles old and not low
[QUOTE=91akira;2298465]91 GS with 240k
-loose steering at highways speeds. Need to adjust/tighten the nut on the rack
-passenger side axle
-All motor mounts
-All bushings expect for the rear trailer arm bushings which was replaced couple of days ago.
thats about it for 2013[/QUOTE]
Update: Loose steering was actually rims and tire issues. Passenger axle replaced with Raxles. All bushings are good. Motor mounts good.
paint… ny car needs paint…
Squeeky noice in the back and some hummming on the wheel probably the bearings.
i too have recently got this creaking/squeaky noise coming from my trunk area, not sure what it is
x3
mine is intermittent(sp?)
Have you tried wrapping your trunk latch with electrical tape? It is the metal u-shaped piece on the trunk lid. Just wrap the center about 2 or 3 times.
New exhaust hangers
New axles
Respray the car and eliminate a little reoccurring cancer
ABS pump
Window rattle both sides
Cluster needs to be re-greased, sounds bad on the colder days
Fix wobble in the shifter, not sure if its the shifter bushings or the linkage why not both!
Swap ECM so the rear defrost won’t randomly come on or stay on etc.
Spruce up the interior, would love to have the seats recovered.
Sway bar bushings front and back
Need to double check but could probably use new trailing arm bushings
Recover my armrest
A couple little rattles here in there in the interior
New fender splash gaurd on the drivers side
153k Aztec Green Pearl DB2
