what oil pump...
hi guys in the middle of a getting ready to build my motor (after im done building my garage in the next month or so…)anyways ls motor,plan on running max 22 psi at most,on a 57trim t3/t4 will i need to get a type r or gsr oil pump?i just want to make sure becuase im going to buy a new oil pump anyways for the build and dont want to get the wrong thing thanxs alot guys
if ur keeping it an ls then use an ls oil pump. simple. if ur lsvtec then u can use the type r oil pump. which by the way is actualy the cheapest oil pump honda sells.
22psi on a 57trim??? i hope it’s sleeved
what he said and 22psi good luck on the internal and fully balance block also dont skimp on parts and bolts and especially on torque bolt spec and order.
I just went through this myself. you can use the LS, and for future reference’s all B-series oil pumps are interchangeable.
