Here is the engine:
B16a w/ 50,000 miles on it
Dc 4-2-1 header
exhaust
AEM cam gears
AEM pullies
MSD ignition
If you were to put a gen2 Drag turbo on this engine what psi would you run? Is it safe to run 9?
Here is the engine:
Dc 4-2-1 header
exhaust
AEM cam gears
AEM pullies
MSD ignition
I’m runnin 8psi on my stock B16, with an FMU and VAFC(set to run really RICH). I want to run 10psi, but I’m waiting till I get my Standalone ECU. Tuning is the key as everyone will tell you, especially with the B16’s stock c/r 10:2.
I will agree
dont go over 10 it shur would be a damn shame if you blew it and had to bulild that succer or buy my block.
so to keep it safe lets say I will run 9psi. There shouldn’t been any engine damage caused correct? any less reliable?
Do I need anything else for my engine to run 9psi? any suggestions of things that would be good to have. I am planning on a drag turbo with the blitz turbo timer, blitz boost controller, and blitz (forgot name, goes with the boost controller). Anything else necessary.
Do any of you guys run a lower psi for just driving around town?
Originally posted by Integraracer
[B]so to keep it safe lets say I will run 9psi. There shouldn’t been any engine damage caused correct? any less reliable?
[/B]
Don’t go by a hard number of boost to run. I’ve seen guys blow their engine with 6psi. I would NEVER tell anyone any psi is DEFINATELY safe to run, cause I have no idea how your engine may react to it. Chances are you will be alright, BUT if you just plan on runnin the DRAG’s FUEL setup, 12:1 and inline FUEL pump, I would not recommend anything over 8psi. MAYBE a 10:1 FMU and a VAFC and a dyno will get you safely to 10psi. Good Luck.
ya what he said.
i was just saying with good tuneing and proper engin setups what would be good for your motor.
i would say safe out of the box drag kit 6psi and you should not have problums.
to get ten
-fule injectors 310
tweek the fmu disk or just get it done right with hondata or zdyne.
-good gas helps and a dyno is key when trying to get reliable hp.
