Ok so I have finally gotten everything together and all parts ordered for my turbo setup, but my supplier wants to know what turbo i’d like with my kit, here are my options and he needs me to pick one asap:
3 different Garrett Turbos:
T31 / T04E 60-1
6 months warranty.
TURBO SPECIFICATIONS:
compressor wheel: 59. / 76.2 mm 60 trim
compressor housing: T04E 0.70 a/r 4" / 2½". (housing configuration may vary)
center section: oil cooled journal bearings
Turbine wheel: 56.5 mm / 65 mm - 76 trim (stage 3)
Turbine housing .63 a/r
T31 / T04B 63 trim
6 months warranty.
compressor wheel: 55.4 / 69.9 mm 63 trim
compressor housing: T04B 0.60 a/r, 2¾" / 2"
Turbine wheel: 76 trim (stage 3)
Turbine housing .63 a/r, 5 bolts outlet flange
T3 / T4E 57 trim
6 months warranty.
compressor wheel: 56.6 / 74.9 mm 57 trim
compressor housing: T04E 0.70 a/r, 4" / 2½"
Turbine wheel: 68 trim
I need to know which turbo best suits my engine:
91 da LS
B18a1
84.8mm cp 9:0:1 pistons
eagle rods
darton MID sleeves
acl race bearings
ARP headstuds
crank work
head work
85a polyurethane motor mounts
injector dynamics/bosch 725cc injectors
walbo 255lph
obd1 conversion with nonvtec chipped ecu with demon running ectune
AEM - wideband w/4wire o2 & guage & boost controller
I will use turbo with godspeed 2.25’pipe/intercooler
which would you pick to begin build??
hp goal: 400!
THANKS! ALL HELP GREATLY APPRECIATED!
