Whats a good turbo manifold?
i was wondering what was a good brand of turbo manifolds that are a good price, i’m not going to need an external waste gate because i’m going to be boosting 8psi MAX. i want to start out with the manifold, so i just want to get an idea of what i should be looking at. thanks
one that doesn’t crack…
I can’t recall on that doesn’t use an external wategate. I suppose you could get one that has the port for a external wastegate and just get a cover machined for it to block it off?
I’d get a RevHard manifold…but they can be hard to find for our cars…
if i didn’t already have my drag mani i would pick up the inlinepro mani in a heartbeat:
cast stainless steel & about 10 lbs lighter then the conventional cast iron ones. see www.inlinepro.com for details.
or if you’re set on an internal wg mani then give south florida performance a call. they do custom manifolds. see www.sfp.net
Oooohh…I like…it’s got good wastegate positioning. I’d be better if the manifold flange was segmented though…I might get me one of those… :up:
how much is that?
i talked to them the other day and they said that they had an introductory offer right now till (i think) the end of august for $359 and it’s usually $399. i heard that this was a very good manifold and i’m thinking of getting one. it’s got a lifetime warrenty on it. call them up…the # is 703.644.1788 and ws addy is http://www.inlinepro.com
