do I need to remove and reroute the 2 lines with fins?
I believe they are power steering lines that run in front of the car to cool the fluid.
they look like they will be in the way.
I’m installing a spearco front mount from a drag kit
thanks
thanks
yea i want to know the answer too, i just noticed that yesterday, i havent begun the turbo yet cuz im in school and only 17, i gotta no bills, let us know
wade
for sure. ![]()
common someone out there must know!
Yeah can take those lines out. They are part of your A/C system. One end goes to that little canister with the glass on top to see if your ac needs recharging, and he other end goes to your condensor. I took mine out when I took my A/C system out.
Those are power steering lines you have there Ian. Are you planning to retain your p/s system? If not, I’d pull your pump/etc, and then the lines you have in your way can be removed as well.
their was a post a month or 2 ago about this im not sure. but i swear couple people pinched their IC in their and kept those lines. i guess try a search if u find the thread (or i) ill post it here. good luck
thanks man yeah I was told to just pinch them in there.
I tried taking the PS belt off and I didn’t like it redline so I’m keeping the power steering hehe
just too much effort when parking!
it’s a power steering fluid cooler. Since most people ditch the PS the cooler comes out with it and it’s a non-issue.
I’m running on 17’s and use a Sparco 350mm steering wheel and I’m the skinniest white boy you’ll ever meet and I can handle no PS, ya’ll need to hit the gym :loser:
j/k
LOL
tempting to remove it again though just to make it a non-issue.
we’ll see how it goes… I’ve got lots more cutting to do of the bumper cover
hey TouringTeg, what kit do you have and what camber kit? u seem slammed with very well corrected camber
thanks
wade
I have the drag turbo kit that I’ve bought of 91blueteg
it will be here wednesday (damn UPS)
hehe… yeah I have ingalls camber kits front and rear with polyurethane bushings.
the fronts are maxed out.
yep I love have a perfect alignment and still riding low
i mean body kit, im going turbo, but building a block on the side for it, i got a ingalls and its maxxed out and im still negative and im not lower then you…
whoa thats crazy.
you must be lower than me.
also I think there is an extreme kit and another kit that doesn’t adjust as far.
factory body kit front with wings west RS sides and rear ![]()
