which injectors to get?
i converted to ob1 i need 1000’cc but do i get it saturated? or peack & hold? i will be running hondata 200
ob1 is satured. Why 1000cc’s??? how much power are you planning on making? that’s alot of injector, you might have to put in a resistor box and run peak and hold injector. I don’t think they make satured that big.
450hp or so maybe more
presicion 780’s are rated at 125hp per injector
usually the super high flowing injectors are peak n hold. DSM 450s top out at 300-325.
750cc would be perfect for 400-450whp…
Remember bigger isnt always better, regardless if your going to scale them down… You’ll run into spray pattern problems… I just learned this due to an overly large injector on a 1000+hp car :slight_smile:
