i just purchased an Innovative LC-1 wideband. i know that the sensor has 2 analog outputs, one to run a gauge, and one to feed a signal to the stock ecu in a 0-1v interpretation so you don’t need to run two O2s. now what i want to know is where is the wire that i should be hooking this output to. does it come out of the ECU some where? thanks!
find pin D14 (if OBD1) and cut the wire going into the ECU and connect the wideband output there
read his sn… for some reason i have a feeling he is obd0.
yea im obd0 and ill be running turbo edit.
C16 for OBD0
