ok so the oil pump,full gasket set,water pump,timing belt with tensioner and arp head studs are in shipping process.
pistons and rods are in.
Glad to see you taking care of the db2 ![]()
damn doin work in the complex! keep it up :dance:
just torqued down the main caps and rod bolts.waiting till monday to get the rest of the parts that i ordered then its going to be a complete bottom end. will have pics and updates monday. i came across a problem. I LOST THE KEYSSS. this really sucks.i will be calling the dealership to see if they can get me a new set of keys. I’m so pissed because those were the original keys when first bought. sucks
updates will be up soon. water pump,oil pump,tensioner,main seal are all installed.arp heads are on. just waiting on my friend to help me put in the pistons and rods in.will have pics todayy.
getting a new alternator and bottom pulley.new clutch too.
get it in good shit
finally done with engine bay shave only the drives side tho.will have pics tomorrow.
damn dude…nice work…subscribed.
lookinn really good man
as said .pics of the shave are here. primed it and then filled in a few more holes.still need to sand down a few parts prime it again and paint it.
a few more holes and im done
installing new valve stem seals
finished product.
You’re not going to paint the whole engine bay? Are you going to replace all of the lines, wires, nuts/bolts that you painted over? Is that rattle can paint?
lots of questions,but yes i will changed all the nuts/bolts, No I’m not doing the whole engine bay I’m just too lazy and need the car up and running like asap. yes its rattle can paint.
Good job on the shave job, but you should paint the whole engine bay the same color man!
What is the point of shaving the engine bay if its a different color on half? You should have left it how it was.
well the engine will be together soon and I;'m just not so patient anymore,too busy with job and rest of the things i have to take care of right now. i need a car asap. I was thinking of painting it in 4 different colors.right side in purple.left side yellow.firewall blue and the front yellow,something like that but right now I don’t have time to do all that.
some new updates
gripforce stage 3 clutch and 9.75 flywheel will be here monday
