dual exhuast doesnt make sense unless it is twin turbo.
the exhaust system is as big as the smallest point, and in ur case, will probably be the turbo outlet. make a single pipe going staight out the back. For a stock block u will not need that open of an exhaust.
How do people get away with a dual exhaust setup then ? I see lots of integra’s and civics at the track running dual setups. nothing special done to the cars, they run same times as everyone else. Is it because they run 2 1.50 pipes and put ricer tips on ?
generally the split point in the pipe is right after the rear LCA. when the weather is colder out and cars tend to steam/smoke a bit more noticably you will notice the smoke only comes out of one pipe, the passenger side one.
the dual setups on 99% of the honda civics out there arent doing anything at all except in the owners eyes making the car look faster.
not entirely true. if it were length would not be part of the calculation for resistance. two mufflers in parallel flow way better than a single muffler too.
Wouldn’t a true dual exhaust require a set of 2 - 1 headers extending to the end of the exhaust system? I believe this is possible as long as you have the ability to maintain exhaust velocity towards the higher rpm (to completely eliminate the exhaust so that no exhaust gas has probability of creeping back into the combustion chamber).
With a turbocharger (or at least an engine mated to one turbocharger) you will have exhaust from all 4 runners go through the turbine and then out one opening. If you wanted to have one pipe split into a pair of pipes to achieve a dual-pipe - to - tip setup…
Originally posted by MichaelDelaney
as long as the total cross-sectional area of the 2 tubes (or the total summation of the diameters of the 2 tubes) is not more than the area or diameter of the single tubed exhaust that’s been properly sized for your peak hp goal, you’re ok. If you exceed that then, it’ll be gutless in the low to mid rpms…and slow in acceleration.
i read that like 4 times, now my eyes hurt. maybe i will go shower and try reading it again in a bit. which part of my statement are you looking for proof of?
say you want a 4" stick. to split into two, you need two 2" sticks. now an exhaust is measured by the cross-section, a circle, so you need to use the formula for the area of a circle, pi*r^2.
3" exhaust = 2.25pi square inches of cross area
twin exhaust = 1.125pi square inches each
each should be about 2.12" in diameter
if u honestly wanted it. i can see someone doing what the accords have. have a single pipe running and then a y cut into two diffrent mufflers but it just seems like more weight to the rear of the car…
josh
