Changing a radiator is quicker than changing the oil, unless you run into a problem or something. Seriously, it’s in betweeen changing the battery, and changing the oil.
Okay, so I put it in the car tonight. It was a hard fit, but only because my intercooler piping touches the radiator on both sides. The fan mounting holes were a little off, but it’s really easy to make some bracket (which I was already using in the first place). For some reason, it seems to hold the same amount of coolant, even though it’s twice the size. I drove it pretty hard up a bunch of mountain trails for a good two hours, and the needle stayed right where it did with the stock radiator (which was a little higher than before I had the turbo on). But it held steady. When I get more time and money, I will look into getting some pusher fans like in the picture on page two, and make some ducts to cool it off a little better, and I’m sure it will run much cooler. Otherwise, the radiator from radiatorbarn.com get a thumbs up for me so far.
Stu
what radiator did u get and what year? I’m in need on one asap my damn teg with a b16 over heats then a mutha.
I just went to www.radiatorbarn.com and picked out my car and ordered that one.
just installed mine works perfectly definitly recommend radiatorbarn even customer service was cool
Yes, they do. The switch is located right next to the oil filter, mounted in a large hex plug that screws into the oil drain passage.
