Thanks bro
I was local lol the car still is but I am temporarily in Colorado
The recaros are 92 Mitsubishi evolution 2 Recaro SRD’s
For every motor that has been in this car (its on its 3rd b series now) I have used the same mounts OEM 92 integra mounts with energy suspension inserts and my trans mount is filled with 3m window weld
with the newest motor I am buying some new mounts but it is only because I am going fully hydraulic now.
hey sorry I didn’t get back to sooner but I have a few pics of it and I have to find them.
but what I did/do is remove the battery and fuse box and pull the entire harness inside the cabin. then I de-loom the harness and de-pin the larger plugs that have to go to the headlights and whatever else you are deciding to keep functioning on that side (after making pin-out diagrams).
then I route the wires I need for the front end through the door harness grommet after I tape and cover them in my loom of choice. Sometimes it is easier to loom them after you pass it through the grommet. once it is into the outer fender area you can measure to see if you need to extend anything (on DA’s you will have to extend the passenger side) once you extend your wires, usually 6-9" is enough, then you re-pin your plugs and mount your wires as high up on the frame rail as possible using nickel plated wire clamps/guides used nickel or zinc plated ones or they will rust. Also the reason you want your wires as high up as possible is for possible sag and tire contact. Yes that sounds odd but trust me I didn’t mount mine up high on my personal car mainly because I never thought I would slam my car and I had inner fender plastics and blah blah. Then I was driving my car and all of a sudden my fogs stopped working then the headlights went out, then I could only get the headlights on if I turned the fog switch on and I couldn’t figure it out. I drove the car like this for about a month trying to figure out what happened and I trusted my wire tuck so I didn’t ever look at it. well I was randomly test fitting some wheels and looked into my wheel well and I saw it. the wheels I had on the car wore right through the inner fender liner and ate the wire loom and shorted out 5 out of about 11 wires in the harness. For some odd reason no fuses were blown but all five were twisted together and causing all sorts of weird headlight issues.
So if you are going to somewhat stance/lower your car or stance it out/ slam it or go with bigger wheels in any way just be on the safe side and put the wires high up on the frame rail and route the harness as far away from the wheel arch as possible.
I have also had to repair other people’s wire tucks for very similar reasons
one in particular involved and improperly mounted hid ballast in the wheel well area that was destroyed by some low offset wheels. Almost set my friends car on fire lol
so if you are going to take shortcuts on your own car write down every one you decide to take so you can be prepared when something goes wrong.
Some shortcuts are tried and true and others are just lazy or possibly in a pinch you do what you gotta do. Either way keep a written log of everything you do and it will save your ass on the highway one day. Trust me I try a lot of random things and attempt many different things that most wouldn’t do but I always write down what I did and where so I can go there first if there is an issue.
Well that was a bit a ranting but I have a lot of updates for you guys.
A lot has happened with this car over the last 7 or so months and I think some of you will enjoy it others may not because the car is out of commission for a little while.
but here is a teaser pic for now
