Dan I appreciate your comments I really do. I’ve respected you for a long time and in fact, your car is the main inspiration for my build. Yours is the reason I bought a DB2 in the first place. I truly hope that none of this or what I’m about to say will hinder our future conversations or advice I may seek at any point. I’m sorry if I got you involved here. There are some fundamental points that everyone is missing and the very things that are getting under my skin.
SOME OF THIS IS BOUND TO COME OFF WRONG B/C I’M BEYOND UPSET AND VERY TIRED.
#1 despite what J is saying his intentions were, read his post. You saying that you are worried about my build does not equate to my doing the right thing or that you think it’s going to be fine. To me that clearly read like he basically wrote off my build was going to fail before it’s even finished. When I called him on it, he spouted off a bunch of speculation and random information that, I’m sorry, was wrong. It perpetuates the myths surrounding an engine combination that have been dis proven time and time again. To stick by the info clearly outdated and proved wrong is just silly and stubborn. He was adamant about ls/vtec failure, unlike you Dan(G2Guru) who acknowledge what is actually fact. When I quoted a source far more knowledgeable he continued on his path, then got all pissed off because (i assume) i may have implied that the reason builds he’s seen or was associated with have failed was because of him. i can apologize for that. I threw out the information you got from honda b/c it’s clearly speculation. If you’re basing your whole argument on that piece of paper, I have to say something.
“There’s no data that’s available to the engineers at Honda R&D that says there’s any difference in the alloy used in the B series blocks, VTEC or non-VTEC.
All of them spec at the same hardness in our own testing.”
More from Larry. Done his own testing.
But I can not, nor will I stand by and be made out to be a newb just b/c of when I joined the site, or my age, when I’ve done my homework. I will also not blindly take advice just because it’s from someone respected on a site if I know for a fact it is false. Period. J you’re wrong about oil squirters man, sorry. They were not put there for lubrication they are to cool the piston crown. Look at their position. They shoot right at the bottom of the piston. That’s to cool it down. Not lubricate it. Furthermore you implied that there were several causes of failure in the ls/vtecs you’ve seen and built but never once told me HOW you determined where they failed. NONE of your posts at any point led me to believe you thought i was doing the right things OR that you thought my build would not fail. Not one. You were more focused on trying to discredit where I was coming from and where I acquired my knowledge. If that wasn’t your intention, you need to take a good long time to learn how to express yourself b/c it came off all wrong.
#2) DB2-R81, if he’s a knowledgeable and respected member that should be listened too maybe instead of calling names and acting all tough, he should have posted some things to show off that knowledge. Instead there isn’t a single post where he has demonstrated he should get my respect, or that information in his brain is worth knowing. I have nothing against old guys. I have something against old guys who believe they should be listened to simply because they are old. If I know you’re wrong, I’m gonna tell you you’re wrong. The bottom line here is he came on here to start shit and succeeded by calling me and my friend names rather than actually contributing to the conversation in the ways it was needed. Take a hint man. Look at your posts. "Hey fresh face, come back when you’ve got some grease under your finger nails. J. has more experience with these engines then you and all your midwest butt buddies combined.
Ignore the help and run off to the Dominican with your boyfriends!"
"You’re only demonstrating your inexperience and ignorance more and more.
Same old story, grow some pubic hair then tell us something we have not heard before.
J.’s conversant enough to speak for himself, and akin, likely won’t waist his time attempting to educate the unreachable."
“Like I have implied all along your dreams and attitude are much larger than your brain. Take a step back, do your thing, then tell us about it, that is all.”
“Keep the rhythm going there butt buddy, your making my day!”
“Never said it was correct, and I am not looking at it you and him are! Daaaa…when are we going to talk about the main oil galley, crank oiling passages, and oil filter pads?”
“How about go fuck your self, specific enough!”
This is how he acts like a respected member of the site, and how he acts when called out.
You obviously command some respect around here. You made a bad move. You assumed we didn’t know anything. Then you proceeded with the childish comments. Knowledge called you on that as well, and we have yet to see anything but.
How in the world you command any respect after this I will never understand.
#3) You guys seem to want to swing from J and DB’s nuts talking about how they are the go to guys when it comes to building hondas. Can you seriously read the posts and tell me you still think these things. I’m by no means an expert but I have been around these cars long enough, and done enough reading to know when I’m being fed a bunch of crap. You should think about how these two reacted when they were called out. Archon you think I should listen to these guys after they way they approached and talked to me and my friend? Seriously?
Bottom line, I’m not some pushover newb like you all thought I was, nor is ricecake. You made the assumption that I didn’t know what I was doing, and my thread was to get advice and seek help. Wrong. I wanted to show off a bit b/c this is the first major build I’ve done for my personal car, b/c I finally have the time to do it. I’ve spent a year building up the funds and knowledge to do it, I’ve consulted what are in my opinion the best minds of the times, and the guys who have built what I’m building down to the last bolt, and been successful with it.I am not opposed to advice, but if the advice is thrown in my face, and in my research I know it to be wrong, I will not just swallow it b/c I’m told to or b/c I should simply because of who it’s coming from.
J and DB2, It’s going to be very hard to change my opinion of you two. You guys ruined whatever credibility and/or respect you could have received with the way you both approached me. IF that gets me on everyone’s shit list fine. If that ruins my own credibility b/c people would rather listen to you two, fine. It’s their choice.
I am sorry I lost my temper. But now I really don’t care anymore. The high I had over this build is completely gone thanks to a few who got all upset when they were told they were wrong.
I am willing to move past this and give it a shot again. I like this site a lot. I wanted to contribute the knowledge I’ve acquired over the last 5 years of really digging into Hondas. I still want to. This escalated nearly to a point of no return. Let’s not cross it.
I would like to get the shortblock done, and I would like to get the valve to valve clearances checked as well. If we’re lucky and the dowels show up I might put the whole thing together.
