[QUOTE=Jeffaj20;2266094]Wow… Such a great build! Great progress as well! Keep it up.
SUbscribed[/QUOTE]
Thanks!
As of right now, I am going to the exhaust shop Friday to get the DP & Mid pipe flanged. Tuning appointment is set for Monday morning. I’ll get some pics up over the next few days.
Good and bad. The bad: The boost solenoid would not respond to the ecu settings. It turned out that my ECU was not setup for Boost control. When I Purchased it, I was told it was and I really did not think to check. Unfortunately, we couldn’t adjust the boost :sad:.
The good: We were able to tune on the Wastegate Spring. It ended up putting down 206 wheel @ 8.6psi on a DynoDynamics Dyno…not too shabby. Looking at another 70 hp for the next tune once I get the correct pins in place. This turbo rocks!
A buddy of mine recommended checking out this turbo. He has it on his Miata and makes 300whp. I wanted to see if I could make use of the slightly higher top end and gain back some of the spool time with the .48 housing compared to the 60rs. So far I really like results…cannot wait to turn the boost up though. I also was looking for a slightly used Turbo to save some cash…I found the 71r was a little easier to find and at the same price.
Took some quick pics on Sunday. I will post some new engine bay shots soon. I finished the charge pipe, got some goodies cleanup up a few things. The car will be at Wekfest NJ this coming weekend.
[QUOTE=BLKACK1;2270828]looks good Jon. love seeing you car. Always take me back to when I was on the E.C. the new digs are a load more impressive then your last spot.
congrats on those number and good luck on getting that pwm going:up:[/QUOTE]
Thanks Glynn! Love the new spot.
[QUOTE=PR8urVTEC;2271674]That build came out perfect. Everything just looks immaculate all the way around.
-Ryan[/QUOTE]
Thanks, appreciate the good words.
[QUOTE=Sleeperzzz95;2271712]Wow… Love it! :dance:
Dunno if I missed it. But what was your first Turbo setup an how much did it put down and where to get one? Also Where did u get your C/F lip from?[/QUOTE]
Thanks. The first setup was a TSI Kit. It had a T25. Put down 180 at the wheels. Lip is JDP.
It’s been a few months since I’ve posted. Happy New year.
Thanks for all the kind words on the build. The car is now put away for the year. Took a few pics in Late November. Got some plans for 2013 and a photo shoot planned for the Spring. I’ll post pics of progress once I start.
Did some work on my Subaru this fall. Timing belt, water pump, Head Gaskets, gaskets/studs, valve seals, idlers, tensioner, belts.
