whats that big aluminum looking block on your harness?
It’s a resistor box from an EVO, it’s for the 10 ohm injectors that I’m running (450).
nice job on the harness turned out nice.
Thanks man. I put about 20-25 hours into the project. It’s such tedious work.
Wow, Impressive
Dude your build is so freaken good it’s almost discouraging Almost.
I think I’m going to try to redo my harness like you that looks really good. Did you alter it for tuck?
Thanks!
[QUOTE=teggyguy;2291425]Dude your build is so freaken good it’s almost discouraging Almost.
I think I’m going to try to redo my harness like you that looks really good. Did you alter it for tuck?[/QUOTE]
Haha Thanks man! Good luck with your harness. I basically measured everything and either extended or shortened wires based on their locations. Now that the harness is in the car you really can’t see any wiring.
Took the car for it’s first ride of the year! My brother was nice enough to snap some photos of my car.
DA.03.2013-3668 by Mdeck333, on Flickr
DA.03.2013-3661 by Mdeck333, on Flickr
DA.03.2013-3666 by Mdeck333, on Flickr
DA.03.2013-3648 by Mdeck333, on Flickr
DA.03.2013-3631-2 by Mdeck333, on Flickr
Looks great! Nothing like taking it for a spin after a bunch of fresh work has been done
Thanks Man! Yeah it felt great to drive it. I’m really digging the spacers and decals on the wheels too.
Gorgeous, simply Gorgeous!!!
[QUOTE=jdecks23;2269811]Thanks!
car looks amazing man! what is the silver heat tubing called that you have over your wastegate lines. im drawing a blank and need some for mine and cant think of the name or term for them. thanks
This sums it up.
Very awesome work man. So many nice builds coming out this spring, I love it!
Looking really good Jon. We should get together for a photoshoot sometime later on in the spring, although I’ll have to clean mine up a little so it doesn’t look so bad next to yours!
Nelson, where have you been hiding??
I forgot about this site for a while! Haven’t really done much with the teg because of work, but there are a few changes I’m thinking about. Seeing Jon’s progress definitely makes me want to work on the car this spring. How have you been?
Thanks Nelson! I was wondering where you were. I’m down for a photoshoot for sure!
[QUOTE=unified112;2292230]This sums it up.
Very awesome work man. So many nice builds coming out this spring, I love it![/QUOTE]
Thanks Man! You’re right there are some great builds happening this Spring! Very impressive and inspiring.
It’s just DEI “Cool-Tape” I’ve got some on the oil pan too near the DP. As far as vacuum lines go it works, but it isn’t the best solution. Eventually, I want to get some of this for the WG lines. This is the orange stuff you see on race cars.
Thanks Man, your build is looking great too!
Spent the last few weeks doing some work on my garage. Patched up the walls and painted everything. I also added some more lighting and wired it all to the light switch.:
thats a very nice teg dude! nicest blue one ive ever seen
I should stock a mini fridge down in the shop…
