updated: as of 09/11/05
turbo project is on again…
this time i got a job… hahaha
setup now…
one of those “custom tubular log manifolds” with external wastegate
turbonetics wastegate
T3 ford thunderbird turbo (.42/.60 i believe)
all kinds of custom 2" chargepiping/hose from turbo to FMIC, then 2" then 2.25" from FMIC to TB (all drag piping from ebay auction might come in if i win )
forgot the kind of BOV i have, but im borrowing it, and it looks like a rocket…
2.5" downpipe w/ flexpipe. looking for a Y pipe so i can run full exhaust, then unbolt the plate to run open downpipe…
obd-0 to obd-1 harness & misc. other things will be here soon
hondata s200 w/ boost will be around sometime soon
RC 370 injectors will be around sometime soon aswell
status as of 2:24am sunday sept. 11th - turbo/chargepiping/FMIC installed
tonight or tomorrow morning todo - oil feed/T on firewall/sensor/return/oil pan
then once everything is in running condition… i’ll make an appointment with a muffler shop near my house to get the downpipe & all made…
this fulltime job thing is kool…
:danger:
what i have
drag gen3 manifold
garrett T3 turbo (i do not know the specs)
audi intercooler
drag kit wastegate
7psi fmu
flexpipe
what i need
check valves
bov
bov flange
a few things fabricated (charge piping & dp)
should i chip?
the turbo has the downpipe flange on it, with a piece of the downpipe still on there. i can build from there.
so far, all i need to get it together to be able to run, is to tap oil from the back, drill a hole, seal and bolt up the oil drain, make charge piping, and downpipe.
my setup right now is basically a LS w/ '92 cams, aem intake, DC 4-2-1 header, 2.5" test pipe, RS*R exhaust. and it’s pretty quiet.
if i run this turbo setup that i’ve listed, with an aem intake, along with the testpipe & RSR exhaust, would it be fine? would the 2.25" of the RSR be too restrictive? should i get a split valve to run open downpipe after i get everything together?
i plan on running about 6psi for now. after i get more money in for better management, hondata s200 w/ boost, then i’ll see where i’d go from there, but for now, i’d like to see how it is, and if im capable of doing it.
is there anything im missing? i still need to go search around for the best size for charge piping… and i need to find the best way to route the chargepiping for the intercooler (it has both inlet and outlet on one side, kind of like a backdoor style)
