my ls-t to ls/vtec-t
Cant wait to see this thing running!
you’re telling me brah! picking up the head this week. and taking two weeks off (june 3-19) to finish it up.
engine is going in this weekend. oh and i got myself some type-r cams. time to make some decent power.
its getting there
Dam, thats sexy!!
cars running!!! i put 200km on it today. engine’s running amazing. nothing like my other ls/vtec that had problems right from the beginning. bit of smoke under accel until i hit about 40km and then it stopped. i suppose the ring’s set well pretty quick. tomorrow im getting a street tune done to get the idle, part throttle, fuel cut etc. stuff done so that the car drives stock and has a perfect air/fuel for the 1000km break in i’m doing. once i hit 1000km which won’t take long i’m going back for a full power tune and i’ll post the results. :smiley:
good shit brother man, cant wait to see the numbers shes gonna put down
:up:
whos tuning this beast?
John from JS Tuned. i changed tuner this year. got a street tune today. idles good and doesn’t run rich anymore. it’s boosting at 9 psi right now. haven’t brought the rev’s over 5000rpm yet but i will slowly be bringing them up tomorrow.
some pics from a meet last might. sorry for the angles i didn’t take these pictures.
wow gr8 work man very nice and clean
looking good. your realy making me want a set of hood struts. :slight_smile:
you got all this work into this thing and still got the A/C core in there LOL :up:
the worst part is i’ve removed the dash twice. minor details :wink:
was strapped down on the dyno ready to go when my iacv died and my wideband also. :frowning: stole a iacv from my friends car that was in the shop so it runs now but will only get the wideband tomorrow. probably go back on the dyno tomorrow night. and i also have a ticking sound coming from my transmission now. it’s pretty loud and when i push the clutch in it stops. going to wake up early and remove the trans and check it out. might have to open the casing if i don’t see anything obvious with the clutch or flywheel.
Oh no… Best of luck bro! Hey are you still running a stock fuel rail? I’m curious to see what you hit on the dyno!
hopefully its an easy fix :up:
ya still using the stock fuel rail. so i took the trans apart today. everything looked fine except my third gear synchro which i knew was finished. the clutch also looked fine. reassembled it all and still does the same knocking sound. definitely coming from the trans. when i push the clutch in it gradually goes away and if i push the clutch and put it into gear right away the knocking stops instantly. if i leave it in neutral and just force the shifter into any gear the knocking gets louder. it’s very weird. i’m looking for a ls ys1 now.
