LOL, all I got from that was “photo”. So I assume you want an update. Things have slowed down a bit at the shop, so here I am with some time to waste, here’s what we’ve been up to.
Installed the 70mm S2 Alpha TB
Had to make some fuel line brackets to run underneath the beast.
Took a few of these:
TIGed them together and painted them to make these
All installed
Made our own rear bumper bracket, weighs almost nothing, allows for quick release, and easily adjustable.
DA JeLLie. Thanks! The sandblasting is a life saver man, it reveals all the porous metal and weaker spots that you should replace… truly is a NEED in my eyes.
Little update… Couldn’t even turn the wheels that much without rubbing the fender.
Had to roll the fenders and do a slight pull to clear the wheels
Thanks! Hoping to get her fired up by next weekend! I am sooooo excited! lol
[QUOTE=unified112;2292191]Seriously. It’s definitely one of my favorites!
What are the specs on your wheels and tires? I’m not sure if you’ve posted that or not…[/QUOTE]
Thanks, I can’t remember the exact specs, but I will find out for you tomorrow for sure… I know my tires are 225/50/16… had a rubbing issue so I rolled the fenders w/ a slight pull (because I like the look as well), took care of the rubbing, with lots of space left over for suspension travel.
Installed it beside the main power switch… (I love flicking the main power switch… so much fun lol)
Then, Had to install the AEM Wideband gauge, came out pretty sweet
Finished the harness, mostly, we just have to wrap everything, we fueled it up, started setting up the basemap on the EMS, and hopefully get to hear her roar tomorrow
And finally, a shot of my 2 beasts… I love CF as you can see lol
Much to my dismay, the beast didn’t start :(. It’s depressing yet exciting. The reason is that even though the AEM EMS is calibrated to work with the honda distributor, it really hates it…a lot, lol. The signal is very weak…blah blah blah. So… Coil-on-Plug setup it is! AEM EPM on order. Using CBR 600RR ignition coils. Just need a few more things…this should be interesting.
