People have been asking for pictures for a few months. I finally got them taken…
Moroso catch can with PCV valve on top. The PCV system is neccesary to keep from blowing your piston rings. By using the catch can you can seperate more crap out of the system before it goes back into the intake.
There are 2 small pipes in the intake pipe pre-turbo, one is facing into the air flow, one away. The hose seen here on the intake pipe is the one facing into the air flow, it goes into the nipple on the vlave cover. The hose going into the can is from the crank case where the OE PCV valve normaly is.
External oil filter, WIX 51515 Ford Mustang Oil Filter
MSD fuel pump and the Crane LX 91 coil mounted where the OE fuel filter bolts to the fire wall. The fuel filter (K&N) is now inline.
2 of the hoses for the reworked PCV system. Can also see the Missing Link check valve.
Profile shot of engine bay. Please excuse the zip-ties on the spark plug wires, they’re a work in progress.
Vortech FMU 10:1 ratio, fuel pressure gauge in fuel rail, you can also see the B&M fuel pressure regulator hiding behind the strut bar.
Permacool 12" High Performance Electric Fan (1650cfm), and Permacool 10" Standard Electric Fan (900cfm).
Tial 35mm wastegate and HKS VBC. The wastegate has a bypass pipe coming out of the bottom of it that is plumbed back into the exhaust system.
Sorry about the crappy lighting.
Interior shot. I like the Sparco steering wheel
Note turbo timer where change tray used to be and radio head unit in glove box.
Gauge panel with autometer oil temp, oil pressure, water temp, and AF gauges. Apex SAFC in center console. Note the switches where the ash tray used to be. Momo Cobra shift knob too.
Crane Cams HI-6 ignition box. Out of the way, dry, and easily accesable to change rev limit.
MTX Thunder 6000 12" sub with MTX amp in a false floor. Like the enclosure for the tool box?
No more back seat, no more passengers to slow me down.
External master shut off switch and Moroso battery box.
Tried to get a shot of how the bumper support has to be cut to fit a front mount intercooler.
More details at http://www.beesandgoats.com/integraover.html
Any questions?
