Post pics of slammed (low as hell) tegs
IM on Yonaka DC coilovers and they r like exactly the same as FF type I and they ride great but can only go down about 3" are they the same for you
im not sure how low they go but right now the front is all the way down but im sure i can get it down another half inch and the back has like another 4 inches to go down
dont mind the :gay: license plate
Do you have to put grind plates on over the oil pan and tranny? I would go lower, but I think that I will just get air ride and ride as low as possible till I need to raise. Just too afraid to trash the underside.
[QUOTE=b18integraboy;1958273]ive been having lots of trouble with these. the rear is way to low and i have it raised up almost to its highest point and the rear is still tucking. the front is perfect just having trouble with the rear.
oh yea its a DA application.[/QUOTE]
That sucks… I was planning to get them too but if you can’t raise the rear to the desired height you want, then what’s the use? Besides the rear height problem, how does it ride? Smooth over bumps and dips?
B204Door - Lovin’ the look of your car dude… exact bike rack setup I have! :rockon: The stance looks awesome on your DB. You got the Type II’s huh? Did you have any problems with the rear like b18integraboy? Also, did you buy the DA or EG/DC setup? Thanks!
hybrid- thanks man, Yea, I had to keep raising the back up till i got it as close as possible to be even. The back still has another 4 inches to go and the front is all the way down and theyre barely even. I have the EK/DC setup.
koolkid- I don’t have a grind plate under neath the oil pan and tranny, it sucks cuz i have like an inch of ground clearance. il post a pic of my driveway, its pretty much a curb to get in and the oil pan just drags gettin in and out. it fucked suck but waaaaaaaatevaa
Thats on 195/50/14’s…my cat is about 3 cm away from the ground…tranny, and oil pan are less than an inch…my K member and that brace underneath eat shit and reflectors all day
i thought they didn’t make a tire under a 60 hight for 14’s
Whoops my bad…yeah 195/60/14’s
What’s your setup?
Im on GC’s and KYB gas shocks…My upper control arms bang the towers pretty bad…
The rears are KYB’s for a DA/EF and the fronts are for an EG/DC with matching forks…it helped the ride out alot but still a little bouncy for my liking…and the Upper control arms bang the shit out of my towers…
http://www.g2ic.com/forums/showthread.php?t=146261
heres a pic of my DA… only pic i have of it since i slammed it for this local meet we had…
i might as well throw this in since it got the car in it also lol
dumped? they are 14’s btw
for old times sake, because i found a white g2 on craigslist i wanna try and buy and get back into a da!
ek and dc applications are not the same. eg/dc are.
check me out, im new here so dont talk s#!t about my ride!!!
[/IMG]
[/IMG]
i also got…
[/IMG]
makes the car fell real low.
clean son:werd: wudder you drop on?
im on ground controls w/hats…no perch, juss spring in the front, n tokico blues
last time i got bitched at for not being low enough. with summer around the corner and my shit at its summer stance. im sure my car gits in well now :slight_smile:
as bmuch as i hate camber kits i will be needing one soon. for now i got a hook up with some $5 used tires that is working out ok :rockon:
