where to start, i bought my car about 3 years ago, stock for the past 2 then the last year i started saving for a custom turbo kit took me a year to get all the right parts when i go get the car tuned n the 2nd run the turbo blew piece of metal went every were in the engine here is a pic of the turbo so now im build ls vtec 400 wheel hp goal but i want to re wire everything get things i dont need out , hide the brake lines basically have the engine just floating on their
engines is out
about half the wiring
talking all the ac wires out
all the work i did today 12/27/05 all the extra wiring
i havent posted in a while i just started to work on the car again here are some updates
im trying to do a quick disconnect harness. im hiding all the wiring under the fender for the headlights. i simply went to the junk yard and started cutting connectors off so i can do a quick disconnect. this is very time consuming! here some pics
here are the connectors i got from the junk yard
the wiring
left heaf light harness
left and right headlight harness
1 day of work with the main harness
this is how the originial harness looks like
the trash so far from the main harness
i did similar on my 00 teg for wiring. i got a 99 gsr wiring harness(floor, doors, and dash) and removed all of the wiring for abs, cruise, air bags, and sunroof. i also regrouped the wires so that i could make a custom engine harness, relocate my ecu, and run bulkhead connectors for the headlight, horn and fan wiring. similar to your headlight harnesses but they look like plastic mil-spec connectors. good luck with the build, can’t wait to see more pix.
no way i never had time im always at work, the 2 days i have off i dont feel like doing anything, i work 10 hours a day. i just need to get this car running, been sitting for like 4 months, i just got eagle rods, arp bolt head studs for ls/vtec today i did some more wiring work, my good time consuming! but almost done 2 days into the main wiring but comming out clean next on the to do list are the brake lines run them in back of the firewall. i wont have time to work on the car again till another week on my day off
here some pic of the progress i did today
alot better than yesterday
almost there
Well, I would say “almost there” if your rods are still in the box! Repeat when motor is in the car w/ completed harnesses! BTW, nice comeback from that harness-horror!
Just did the same thing minus the brake line relocation/dash removal in my teg. Just have to connect the wires on the passenger side fender rail and Im all done. I dont reccommend it to the faint of heart, it is quite a project. I love the look of a gutted/tucked bay, good luck with everything man!!!
i havent posted in a 2 weeks or so here the update, i re-did the brake lines behind the firewal, wiring is done, im getting my motor built right now in 2 weeks motor goes in! and i came up on a deal 250 for 2 sparco seats cant go wrong
