project 400 wheel hp DA
hey godrift…any chance you might have some time to make a write up about the wire tuck? would GREATLY appreciate it!!!
well tommorrow i install motor, ill take some extra pics
good luck man.
must have tools!
getting ready for the car
new home
first cut while installing axle
suspension done
engine
Looks great! Props to you for all the work, i can’t wait to see the finished project!
Josh
i would not be doing everything my self if my mom never gave me my first tool set from craftsman, i remember my first brake job that took me 2 whole days to do the front only lol now motor swaps
i want to see er in action :up:
you scare me.
i’m almost glad i wrecked, else i would have ended up doing what you’re doing.
so other than the crazy cleanup, what are the specs on your setup gonna be?
It is going to be awesome when its finished, Man.
Not trying to jack your thread but what is the advantage of removing the ABS?
Damn taht edelbrock in there is jsut crazy haha. So clsoe to MC :expressionless: Is that a Non ABS Master/Brake booster?
i never had abs, same master cylinder non abs
specs are as follow
b18 81.5 stock sleeves
cp pistons 9.1
eagle rods 3/8 bolt
oem type r pump
oem gsr water pump and timming belt
cosmetic head gasket the thick version for boost
pr3 head
SuperTech SS valves
SuperTech dual springs
SuperTech ti retainers,
hot tank, 3 angle valve job, surface, new seals
victor x manifold
i think thats it
for turbo im planning on using a gt3076r
Nice looks like a solid setup. Similar to mines in a way. Same turbo, btw, excellent choice on that. I love my GT30R. What cams are you planning on using?
o forgot i have gsr cams i got a good deal on them, itr would be nice though do u have a dyno of ur car?
i just added my oil cooler too dam hot to do anything
Sry no dyno plots yet :frowning: I am running 01 ITR/CTR cams. I ran a 12.6 @ 121mph at 1700’ elevation tho in a 2700 DA. At sea level and better traction out of the hole, I should run 11’s especially with that 121mph
how big r those ic lines?
they look 2.25", why didn’t you use an angled hose end on the filter? looks akward aiming straight up. car looks good tho.
piping is 2.5 as for the oil filter i dint want to spend 20 bucks on a 180 degre fitting so it can be straight thats why its in a angle but it clears everything
I wanna see that in person. :drool:
update i installed the electrical evertything work so i should be fine starting the car i might start it today
