hey i came back from europe and new york. so i had not posted anything in a while, but i did a couple of mods i havent tuned the car yet, anyone know a welder? in los angeles are 90255?
i did my own diy tie bar so my 22mm sway bar would not rip out my chasis , i also took of all the sound detning off, pain in the ass and painted the interior. hope to have the car running by end of this month.
Very nice job! You should have painted the engine bay white or a lighter color to set off the engine since you did the wire tuck so your engine would look like it’s floating…
hey there should be no reason why it should not hold up it takes all the pressure of the sub-frame and puts it on the bar, there was this thread somewhere i will look for it which explain how the force of the bar will work or something like that, i also put bolt through the sub frame for extra support. just for you "XDEep " i will fix that on tuseday
jdmontheway: If you are planning on running 600whp, you’re really gonig to be limiting yourself as there are not many intake fuel pumps that flow that much. At that power level, I’d think about gonig to external pump like Aeromotive
my friend let me borrow his uncle welder its a lincoln 125 plus, so i started to do my own downpipe, now i know why manifolds are expensive, and time consuming, to do any feedback is welcome, one thing can i penatrate this material with the welder ?
lol, i know everything is top notch parts i mated a 1300 dollar turbo with a home made downpipe, i have only welded for about a day or so but i will grind it down to finish and look nice
