i was wondering if i could use my stock injectors n fuel pump for a 7-8 psi setup?
no
pump would work, but better safe than sorry. Injectors most def need to be bigger though.
racing poverty thanks for the input
you asked a question and it was clearly a yes or no situation
the answer was no
go fist yourself
could have used the reason why. but thanks again for your input
heres a
boost requires more fuel, stock injectors/pump only provide so much, i.e. not enough for boost.
im running 10psi on stock pump and 450’s working great now but im upgrading the pump this week
how does it run threw the revs? i have volvo turbo its only small, i plan on only runnin like 7-8psi not much its my first setup. i was plannin on getting bigger injectors but was unsure if i needed too for such a low psi
just get some DSM (aka eclipse turbo) injectors and ull be good for 8 psi with tuning.
i thought they wouldnt fit? and for a setup like that what kinda of tuning could i do?
stock wont work, it’ll work to a point. once i spooled with stock injectors it bugged out bad. once we put the 450’s in and tuned it it ran like a champ
ok im really new to this and i have read the guide n printed it out n read it again at my shop but how can i tune a basic setup like this?
aswell im looking for a manifold if anyone has one for sale?
stock injectors are made for a stock motor, clearly by adding turbo your car is not stock anymore and no the stock injectors cant handle the fuel that you will need to match the proper mixture with a turbo setup
ok i got that…thanks everyone!
but my tuning question…
if its obd0 = turbo edit
obd1 = chrome
its a 91 obd0 then right?
but whats turbo edit???
Its just another free based management system that allows you to use your stock ecu but still be able to completely reprogram it
where can i get it?
