to connect two turbos to one intercooler, all you need is a “Y” Pipe in the charge piping after the turbos and before the intercooler. pretty much turning two pipes into one.
twin turbo’s CAN be done a four cylinder, in theory. but would be the most part counter productive. yeah, for the most part on your theory of cylinders 1 and 2 into turbo A, and cyl. 3 and 4 go to turbo B is correct. as when cylinder 1 is at TDC, so is cylinder 4. i can’t remember the firing order off-hand, but i’m sure for a fact that its not 1-2-3-4 so you’d want to pair up the sets of cylinders in their respective firing order, to optimize flow to the turbos.
i’m open for the discussion, but in essence, it would be a waste of A LOT of money that most don’t have. it HAS BEEN DONE on drag cars, anyone remember that 4000hp drag integra? thats 1000hp per cylinder, thats nuckin futs.
space in the engine bay is also a big problem, as it has one of the more cramped engine bays in honda’s lineup. the new civic’s and rsx’s are a little more cramped, but they are packin the motors that we want (K’s) with NO ROOM to spare lol. they barely fit in there. fitting a much larger manifold setup, with TWO turbo’s and at least until it gets underneath the car TWO downpipes. we have enough problems fitting aftermarket exhaust manifolds and exhaust systems without scraping/hitting crossmembers, let alone two exhaust systems (at least until they are brought together with Y pipe)
anyway, theoretically its possible, but financially speaking, its not worth it. i’d go with single turbo any day of the week.
a setup like this could run in the 5 figure price range, when a single turbo setup, that will bring the same results (if not better), will run you about 2,000-5,000. thats less than HALF the price. its a nice idea to think outside the box and be different, but outside of doing it just to prove a point that it can be done, and being a show car, it would be practically useless.
blu’s 2 cents
